Make or break time
Old 06-11-2008, 10:08 AM
MTBSully's Avatar
Make or break time
Well i picked up the head gasket this morning and right now i am about to install the head bolts. My new Felpro head bolts don't have loose washers like the stock ones did. They just have washer things as one part of the bolt if you know what i mean. Is this okay?
Also, i will probably have to use a universal when i am getting to some of the bolts below the spark plugs. How do i ensure I have torqued them correctly?
Any last words of advice or encouragement?
MTBSully is offline
Old 06-11-2008, 10:34 AM
Dadic 78's Avatar
the washers are built into the bolts, no need for a seperate loose washer.
Dadic 78 is offline
Old 06-11-2008, 10:44 AM
BUBBA's Avatar
Won't the universal work with your T wrench?
BUBBA is offline
Old 06-11-2008, 11:35 AM
MTBSully's Avatar
its will im just wondering if the universal (being at an angle) will mess with my torque readings
MTBSully is offline
Old 06-11-2008, 11:46 AM
BUBBA's Avatar
If you have any concerns about that, I would contact an engine builder and get an opinion. I guess the std tq for stock bolts is 65#s. The bolts you are going to use should have a particular torque spec.
Be sure and torque them in the recommended sequence for optimum assurance.JMHO
BUBBA is offline
10-31-2016 11:09 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
siguy
11-27-2014 10:07 AM
1LEThumper
07-14-2003 12:45 PM
97FormulaWS-6
09-11-2002 11:57 AM
Quick Reply: Make or break time
