major loss of power
Old Nov 3, 2003 | 03:11 PM
predator's Avatar
major loss of power
ok my car is totaly running like a dog will barley brake the wheels loose here is the thing i have done
new opti, new plugs ac delco, chsnging wires tommorow, coil,module,02s,
car has 123 on the clock give me some ideas to get my power back
i was thinking maybe new injectors
it doesnt miss runs smooth
Old Nov 3, 2003 | 05:05 PM
BUBBA's Avatar
How was it running before you did these things? If it was running strong, then you need to check your work, e.g. plugs gapped at .050?
TB plenum on all the way around i.e no intake air leaks after the MAF?
Good luck.
Old Nov 3, 2003 | 05:08 PM
predator's Avatar
i did these to try to make it run better but no luck, no leaks after the maf. i am thinkig either injectors are mad clogged or timing is getting loose
Old Nov 4, 2003 | 02:29 PM
OBE1 95Z28's Avatar
Might check for a clogged cat/cats. My single cat clogged 2 years ago and the car would idle fine but had no power at all.
Old Nov 4, 2003 | 02:58 PM
Terran2k's Avatar
how did u check for a clogged cat? i went to the local minkene and they didnt do it...
Old Nov 4, 2003 | 08:47 PM
OBE1 95Z28's Avatar
I've heard some muffler shops thread a pressure gauge into the O2 bung(s) and measure the back pressure. I've also read that you can just remove the O2 sensor(s) and run the car in open loop...if the car runs better, it points to a clogged cat. How many miles do you have on the cat(s)? When I suspected mine, after double checking air intake, spark and fuel, I just disconnected the intermediate pipe, slammed a broom stick through the cat and the problem was gone (until next time you have to smog!).
Old Nov 4, 2003 | 09:00 PM
1FstFormulaV8's Avatar
Where are the O2 sensors?
warmeck
May 7, 2015 02:10 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
