Main bearing& Cam
Old Sep 24, 2003 | 10:19 PM
HoneyCombs's Avatar
Main bearing& Cam
I was told that as soon as you do heads and/or cam on lt1's that you tweak the motor or something and wreak the main bearings?
I have 160,000 miles and thinking about a new cam?
Old Sep 24, 2003 | 10:26 PM
94formulabz's Avatar
here ya go. It's always a risk modifying a motor, it can be done successfully though. I don't think i'd be cracking open a 160k mi motor, but thats just one opinion.
-Brent
Old Sep 24, 2003 | 11:46 PM
96chargedRamAir's Avatar
Just lost my motor after 3 days of heads and cam on a 40,000 mile block Car was down for almost 1yr and half and now I have 0 Oil Pressure and a weird sound. Sure Wish I would have read about this first.
Old Sep 25, 2003 | 12:01 AM
PoorMan's Avatar
96chardedramair: Did you just lose your motor since I talked with you last?? omg!!
I don't know why this is LT1 specific. Block is not much different from older chevy blocks as far as the stated problem goes. IMO, bearing failure is most likely caused by not enough oil at startup. I think prelubing the engine is important if it has sat for some time. Also keeping the block and bearings lubed if they are to sit with WD-40 or similar to prevent rust. Other than that, dirty installs run second, crap on the oil screen, and crap that marks up the bearings. And not to mention, dropping a cam lob on one during removal.
Jeff D.
Old Sep 25, 2003 | 12:19 AM
AndyB's Avatar
I wouldn't touch a motor with 160k on the odometer. Save yourself the time and money and rebuild it before sticking a cam in there.
Old Sep 25, 2003 | 12:22 PM
motor
Yeap I think its gone =( I have 0 oil pressure at idel and about 5-8 psi driven. thought first it was the sending unit but I changed it and got the samething now the car does not want to stay running. Im going to drop the oil pan in a few days and see what happen I bet I did get on the car but maybe 2 times.
Old Sep 25, 2003 | 07:32 PM
PoorMan's Avatar
Man, sorry to hear that. That suxs @ss just hearing that happen to someone. Yeah, I would cut the filter and check for metal in the gauze padding too. May want to put in some heavy oil, like 20w-50 and see if you get some pressure back.
Jeff D.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
