maf sensor
Old Nov 4, 2009 | 10:14 AM
  #16
Didn't the code for the MAF disappear?
There is no way a problem with the MAF will set the codes for the Opti optical sensor.
Old Nov 4, 2009 | 06:13 PM
  #17
remington's Avatar
yes ,
last time I checked with code reader no code for maf
Old Nov 5, 2009 | 05:39 AM
  #18
Guest47904's Avatar
Guest
Considering that it appears to shut down once it goes into closed loop. And it had a code for O2 switching problem. I would unplug one of the O2's and see if it runs better by forcing it to stay in open loop.
If the MAF were the problem, simply unplugging it should show the problem since that will force the PCM into speed/density mode. Assuming of course the MAP is providing a good signal.
Old Nov 5, 2009 | 07:08 PM
  #19
remington's Avatar
I will unplug maf and see what happens.
Old Nov 5, 2009 | 07:14 PM
  #20
remington's Avatar
car ran the same with no maf sensor Ran for about 10 seconds then started missing and finally stopped after about 20 seconds
Old Nov 6, 2009 | 04:03 PM
  #21
Guest47904's Avatar
Guest
So it would appear the MAF isn't the problem. Now try unplugging an O2
Old Nov 7, 2009 | 10:11 AM
  #22
remington's Avatar
I replaced the one 02 sensor that was showing up on code reader.
I also have a exhaust leak in the manifold. Could this cause the o2 sensor to throw a trouble code?
thanks for the help
Old Nov 7, 2009 | 11:36 AM
  #23
A leak at the exhaust manifold will cause that bank of the engine to run rich. But unless its an extreme leak, its not going to set a "lean" code.
Old Nov 7, 2009 | 12:26 PM
  #24
remington's Avatar
I would say its a small leak. What should happen when I unplug o2 sensor?
Old Nov 7, 2009 | 03:16 PM
  #25
Guest47904's Avatar
Guest
I already answered that question.
SergheiS
Jul 5, 2015 03:27 AM
BigED
Jun 23, 2015 07:19 PM
andrewcapps82
May 19, 2015 10:11 PM
pete53
Dec 9, 2014 07:31 AM
