maf sensor
Old Nov 1, 2009 | 10:14 AM
remington's Avatar
maf sensor
can a bad maf sensor effect the opti spark?
I have a reader and it says replace the maf sensor. I did replace the maf sensor but still have same codes. Not sure whats going on
Old Nov 1, 2009 | 10:22 AM
Provide additional info.
You need a "signature" showing basic info about your car - year, model, engine, tranny and any major mods. That helps people answer your questions accurately.
What are the EXACT numerical codes you are getting? In OBD-I there is only a single code for the MAF sensor. In OBD-II, there are multiple codes. That's why we need basic info about the car, and the EXACT codes.
Old Nov 1, 2009 | 12:41 PM
remington's Avatar
1996 z28 350, codes po102, p1371,po400. po153
thanks
Old Nov 1, 2009 | 02:34 PM
P0102 sets when the MAF sensor output signal reading is less than 1,000Hz, which is outside the minimum acceptable signal level.
P1371 sets when the PCM can not find the low resolution cam position signal from the Optispark. If the engine is running, its a stored code. If its an active code, it shuts down the fuel system and the engine will not run.
The two codes are not related.
P0400 indicates a problem with the EGR recirculation. Is your EGR system still installed and operating.
P0153 sets when the PCM detects slow swithcing (rich/lean/rich) on the passenger side pre-cat O2 sensor.
Describe the problems with the engine, in detail. How does it start, how does it idle, how does it perform at wide open throttle (WOT)?
Old Nov 1, 2009 | 04:16 PM
remington's Avatar
starts ok, idle ok to start with then starts running rough like it not receiving fuel then shuts off. If you try and give gas when it starts to die car will shut off
thanks
Old Nov 2, 2009 | 05:23 AM
Did you check the rubber elbow that connects the MAF to the throttle body? Is it torn, or is the bottom lip folded under and not on the throttle body? Sounds like the engine is getting air that is bypassing the MAF sensor.
In addition, you've got to fix the problem with the EGR and the passenger side O2 sensor.
You also have to clear the codes (pull PCM BAT fuse for 30 seconds, with key "off"), and see how quickly the P1371 code comes back, which would indicate a problem with the Opti, or the Opti wire harness and connectors.
You never answered my question - is your EGR system intact?
Seems like you want to type as few words as possible, and that's not going to help you get your problem solved.
Old Nov 2, 2009 | 06:13 AM
remington's Avatar
egr is intact. I have replaced o2 sensor. Rubber elbow is new and in place.
I will clear codes and see what happens.
Old Nov 2, 2009 | 03:33 PM
remington's Avatar
cleared codes. Car ran for about 45 seconds. while car was running it ran rough then finally shut off. read with code reader and code was po372
thanks
Old Nov 2, 2009 | 05:16 PM
P0372 is for loss of the high resolution pulse signal from the Opti. Appears you may have a faulty Opti optical module, or the short Opti wiring harness, or the connectors on either end of it are corroded, loose or damaged.
Old Nov 2, 2009 | 06:40 PM
remington's Avatar
Is the opti optical module and the short opti wiring harness in the opti?
Old Nov 2, 2009 | 11:34 PM
The optical module is in the Opti case. The harness runs from the gray connector on the bracket on the passenger side of the intake manifold to the electrical connector on the Opti. That's what powers the Opti electronics, and sends the Opti cam position signals to the PCM.
From Shoebox:
http://shbox.com/1/evap_sol.jpg
Old Nov 3, 2009 | 05:35 PM
remington's Avatar
what do you think about replacing the wiring harness before I buy a opti?
I figure that if I have to replace the opti I would want a new wiring harness.
thanks
Old Nov 3, 2009 | 09:07 PM
charliediss's Avatar
Weird, I went through the same EXACT problem, from the P0372 to the car shutting off after it went into closed loop. It would run in closed loop sometimes, check engine light on, RICH RICH RICH. Went through O2s like crazy (autozone stopped taking them back)! Anyways, turns out my MAF was done. I took it out one day and looked at it from the front...looked fine, flipped it around and the backs of the resistors were burn off...bought an aftermarket MAF...granatelli I think, and she has been fine ever since.
Hope that helps.
Charlie
Old Nov 3, 2009 | 10:23 PM
I was going to recommend EFIConnection for a cheap replacement Opti harness, but a quick check of their webiste produced this ominous message:
http://www.eficonnection.com/eficonnection/default.aspx
Old Nov 4, 2009 | 06:18 AM
remington's Avatar
thanks,
I will check maf
