MAF problems
Old Jul 30, 2004 | 07:43 PM
Dave19yz28's Avatar
Thumbs down MAF problems
Hey guys, car has been throwing a code for the MAF. So, I bought a new one...genuine GM part...and i am still getting the same code. Is there anyway to test the MAF to see if it is a faulty part? Any help or recomendations are greatly appreciated.
Old Jul 30, 2004 | 07:57 PM
turbo_Z's Avatar
Re: MAF problems
check your wiring harness.. you probably just have a loose connection. I had the same problem with my car at one time and had to rebuild the connector.
Old Jul 30, 2004 | 11:04 PM
Re: MAF problems
What was the exact code you got? The 97's seem to be prone to the code for the MAF "circuit" and the problem is often a break in the pink wire that supplies +12V to the sensor. Pull the connector off the sensor, key on, don't start engine, and see if you have +12V on the pink wire, and a good ground on the black wire.
Peytons'z
May 6, 2021 09:25 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
3TAS4ME
Apr 15, 2015 02:24 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
