MAF maxes at 400 gps at part throttle
Old Aug 4, 2009 | 12:10 PM
  #16
NVMYZ28's Avatar
So this problem only manifested itself AFTER the car was getting tuned? Everything mechanically is checking out - I would guess something with the tune isnt right. Have you tried sticking a stock tune in the PCM and running it? What happens? If that fixes it, build off of the fresh file.
What about your previous tune? Tried putting that back in?
Old Aug 4, 2009 | 12:31 PM
  #17
AdsoYo's Avatar
The tuner said he double and triple checked the tune and couldn't find anything. He tried putting a GM factory tune in there and it did the same thing, MAF reading spiked under a barely open throttle and car almost died. Unfortunately I don't have my old pcmforless tune anymore.
Old Aug 4, 2009 | 01:59 PM
  #18
sbs's Avatar
sbs
Originally Posted by AdsoYo
I used a wooden clothes pin to hold the black lead of my multimeter to a ground on the chassis. I set the multimeter to "20" under "V" so the screen read "0.00" then stuck a paper clip in each pin of the PCM harness and touched the red lead of my multimeter to the paper clip.
Won't make a significant difference, but you should be measuring relative to the PCM ground. The PCM ground itself you should measure relative to battery negative.
Given the large number of weird readings I would:
1) remove PCM, check all harness pins for shorts to power or ground
2) install a known-good PCM with a known-good tune, and recheck the output voltages
If I was being really careful, I'd disconnect the sensors/actuators that connect to the weird readings before connecting the new PCM. Like, everything that connects to 5V reference. But I'm usually not that careful...
Old Aug 4, 2009 | 05:13 PM
  #19
Originally Posted by Injuneer
You've got to read the notes that are included in the chart. Appears you ignored them.
If you look at the chart, there is "(2)" next to A7. The note indicates "Battery voltage for first two seconds". "0" is the normal reading. The PCM only runs the fuel pump for 2 seconds when the key is turned to on and the engine doesn't start.
Okay... the magical chart says nothing about the fuel enable signal, MAF signal etc....
Pin A7 is the fuel pump relay control = fuel enable signal. The chart contains note (2) for that pin. EXACTLY what I typed for you.
Where did I go wrong? Why the "magical chart" sarcasm? I was only trying to help you?????????
Old Aug 5, 2009 | 01:34 AM
  #20
AdsoYo's Avatar
I interpreted your response as mostly passive aggression, Injuneer. As if I was wasting your, and everyone else's precious time that could've been saved if I wasn't such a chart hater. As if my problem is some kind of burden on everybody right now. Or maybe I'm way off.
The "fuel enable signal" is A25, not A7 which is the "fuel pump relay control". How can they be the same thing? A25 is a dark blue wire and A7 is a dark green/white wire.
I talked with my tuner this morning about all this. I asked him about the MAF signal wire being at .01 when the reference says it should be 5 and he said to measure the frequency like was mentioned earlier in the thread. I don't want to drop $80 on a frequency meter so I'll see if I can find a shop around here to measure the frequency tomorrow.
He also wants me to bite the bullet and get a cable and data logging software as well as Tunercat. I won't be able to do that for about 2 weeks until my roommate comes back with his laptop. Frown town.
Old Aug 5, 2009 | 05:37 AM
  #21
OK.... sorry I offended you. I'll drop out and let more friendly people help you.
Old Aug 5, 2009 | 10:29 AM
  #22
PWR SHFT's Avatar
Are there any more helpful or more friendly people out there? I don't think so. Without you, Shoebox, and Rich too, this board would die. Anyone would be hard-pressed to disagree.
Old Aug 19, 2009 | 02:28 PM
  #23
AdsoYo's Avatar
I took the car to the local "electrical specialist" shop and they said it was the PCM. Apparently with the engine off and they key on, the signal on the wire from the PCM to the MAF would randomly spike. They said the MAF and the wire were ok.
Before, when I was on the dyno, we tried a different PCM with no luck. But what the hell, might as well try yet another PCM.
Old Aug 24, 2009 | 10:27 PM
  #24
Godly96_SS_Here's Avatar
Did you try a new PCM? Did it work out?
Noer
Feb 28, 2015 11:29 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
pete53
Dec 9, 2014 07:31 AM
