Oil comming out of valve cover
Old Aug 22, 2009 | 02:21 PM
SlowMoComotion's Avatar
Hello,
I was wondering if any one knows of a quick fix for my 94 trans am.
The oil filler tube that sticks out of the valve cover is very loose and does not seal properly. The threads on it seem like they are stripped, i can tighten it to a point and then it skips a thread and its loose again. I was wondering what people would recommend to properly seal this unit. Should i go with a valve cover breather?
Old Aug 22, 2009 | 03:47 PM
Get a new tube or clean it up and put a little RTV on it.
Old Aug 22, 2009 | 03:51 PM
nice ill try some rtv on it till a new tube comes in, I assume this is a gm only part?
Old Aug 22, 2009 | 03:57 PM
bw_hunter's Avatar
You can also just screw the cap directly into the valve cover....
Old Aug 22, 2009 | 03:58 PM
Don't know if it is a GM only part. You might find one at a salvage yard.
Old Aug 22, 2009 | 03:59 PM
Isn't the cap a twist-lock and the cover made for the threaded extension?
Old Aug 22, 2009 | 04:55 PM
RamAir95TA's Avatar
I seem to remember threading the oil cap directly into the valve cover as well (before I upgraded my covers).
Old Aug 22, 2009 | 06:13 PM
JasonK94Z's Avatar
My cap screws directly into the valve cover. My tube did the same things yours is doing.
Old Aug 23, 2009 | 12:04 AM
sick9lt1's Avatar
Mine did that to and i just went to the auto parts store and got a little rubber oring to make it to where when i screwed the cap on it did not go far enough to get lose again...
Old Aug 24, 2009 | 10:38 PM
I called local GM dealer and the new tube is $20.00 I hope it comes with everything i need. Untill it comes in it seems the RTV trick did it well.
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
