MAC headers touching steering linkage!
Old Sep 12, 2003 | 11:55 PM
CoUnTryMuZiCZ28's Avatar
Some one help please.... My MAC headers are touching my steering linkage... only a small amount but yet enough to produce some good vibration in the steering wheel.. My friend had the same headers and did not have this problem.. What did i do wrong.. The steering linkage is at the farthest away it can go.. Is there another part i can adjust it from.. I didnt see any.. It only rubs when the steering wheel is at certain positions.. Touches when its straight so thats really why it bothers me.. When im driving normal its not THAT bad but wow when i get on it i feel like im in a vibrator, makes the whole car shake.. NEver did it before and i know its the steering linkage.. HELP
Old Sep 12, 2003 | 11:59 PM
94 CAMRO Z28's Avatar
Try to readjust the linkage. Put it where it orginally was when you took it off. Keep trying different positions. I've never heard of this problem before..
Aaron
Old Sep 13, 2003 | 12:26 AM
RamAir95TA's Avatar
I have a ton of clearance between my headers and the steering linkage. Do you have any pictures handy of the clearance problem? I've also never heard of this issue.
Old Sep 13, 2003 | 12:32 AM
I have BBK headers but there was so much room I was almost able to install them without even removing it. There is tons of room on mine. As stated above..please post some pics if you can.
Aaron
Old Sep 13, 2003 | 12:35 AM
I dont have any pictures handy... sorry... Im going to try to readjust the linkage.. I was there al day doing that after the install and couldnt get it.. maybe i did something wrong... Any onther ideas?
Old Sep 13, 2003 | 12:36 AM
scoobysnax83's Avatar
could it be a broken engine mount?
Old Sep 13, 2003 | 12:37 AM
I had every thing checked when i put my clutch in... not that...
Old Sep 13, 2003 | 12:40 AM
good luck..... Are they possibly ungodly bent.....? I don;t think I've ever heard of this before.....
Old Sep 13, 2003 | 12:46 AM
zhawk's Avatar
Glad I went with the Hookers. Great fit
Old Sep 13, 2003 | 05:38 AM
revtime's Avatar
Is it the horseshoe parts on each side that are hitting?
If so you may be able to bend them in a little to get some clearance.
I was afraid my LTs were going to have that problem but once everything was together I have about 3/4 inch of clearance.
Old Sep 13, 2003 | 03:50 PM
Well, no luck... I was out there for a good hour and a half trying to adjust it... it wont go farther in.. its at the farthest out position it can be... it touches the same as it did before i messed with it.. its only the one side of the steering linkage.. its kinda an even oval though right? wonder why the other side doesnt hit. No one has even heard of this problem.. lol.. i dont believe my luck.. could it possibly be that little rubber rag giving way??? If so is there any place to get a new one online?? maybe a metal one? I wouldnt mind having a tighter feel on the wheel..
PS: its the middle set of primary tubes that are hitting.. not the first one. What horseshoe things and how could i bend them???
Old Sep 13, 2003 | 03:55 PM
Z95m6's Avatar
I've read about this several times on here and i believe everytime it is mac's. Do a search maybe you will find something.
Old Sep 13, 2003 | 03:59 PM
Z95m6's Avatar
http://web.camaross.com/forums/showt...eering+linkage
there is more probably.
Old Sep 13, 2003 | 07:48 PM
12SCNDZ's Avatar
Mine hits, too...Kinda sends alot of vibration through the steering wheel.
Frank
Old Sep 13, 2003 | 07:51 PM
12SCNDZ's Avatar
Hey...That's the thread I started! The oil pressure switch, and starter haven't been an issue, though
Frank
Midnight_Z
Feb 16, 2016 09:36 PM
Rich_z28
Sep 13, 2002 03:35 PM
phantasm99
Aug 28, 2002 11:01 PM
Viper
Jul 30, 2002 02:06 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
