MAC header users (and other ?)
Old Apr 22, 2003 | 11:20 PM
OffspringZ28's Avatar
1. How do i clamp off the first header on the driver side (closest to the front bumper) permanently? I have an exhaust leak and im pretty sure its from there as i can see a thin black streak of carbon coming from the metal band. It is the header that has to be clamped to get around the steering knuckle.
2. my clutch doesnt come up as far as all the other camaros i have been in. the clutch is brand new but if i put my foot UNDER the pedal and pull up, it goes up quite a ways. Is something broken? Cable or something??
Thanks a bunch if you guys can give some thoughts
Old Apr 22, 2003 | 11:45 PM
Mir Hussain's Avatar
I did mine
Old Apr 23, 2003 | 10:37 AM
so did i. anyone?
Old Apr 23, 2003 | 10:43 AM
mobleman's Avatar
As far as the header clamp goes, I used ultra copper sealant on the tube and then slid it into the main header tube. Afterwards I just tightened up the clamp. Never had any leaks... (in that area)
Did you use any type of sealant when installing this clamp?
Old Apr 23, 2003 | 10:46 AM
nope, didnt think i had to
Old Apr 23, 2003 | 10:52 AM
mobleman's Avatar
I cant remember if the Mack Instructions said you needed to do this or not. However Brent Franker has a great MAC headers writeup on his website. Instruction #17 mentions the use of sealant on the slip tube...
The link for the instructions is:
http://www.fastblackcar.com/camaro/mac_headers.html
Hope this helps.
Old Apr 23, 2003 | 12:50 PM
Laymaster's Avatar
Hope this helps.
That's Jordan Musser's site...
Old Apr 23, 2003 | 03:49 PM
mobleman's Avatar
oops my fault,
My apologies to both Brent and Jordan
Old Apr 23, 2003 | 05:06 PM
Venom151's Avatar
Ditto here with the Hi-temp sealant. Used some and no leaks, but bought a second clamp and installed them side by side just to make sure. It's a tight sqeeze working around that steering shaft.
Midnight_Z
Feb 16, 2016 09:36 PM
CARGASM
Sep 4, 2002 11:17 AM
phantasm99
Aug 28, 2002 11:01 PM
Viper
Jul 30, 2002 02:06 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
