M6 Questions.....
Old Dec 29, 2003 | 05:24 PM
87transam383tpi's Avatar
M6 Questions.....
First off i did a couple searches but couldn't find anything on this........ Has anybody hooked up a trans cooler for an M6? or a temp gauge. if so how/what fittings are you using on your trans? thanks
Josh
Old Dec 29, 2003 | 05:27 PM
OBE1 95Z28's Avatar
The fluid in the M6 isn't pumped so I don't know how a cooler would work. I think the only challenges with M6 is bent shift forks...not heat related.
Old Dec 29, 2003 | 05:30 PM
well i've never heard of problems either, i just figured a 1pass frame cooler couldn't hurt to get it a tad cooler.........
Old Dec 29, 2003 | 05:37 PM
hsyr's Avatar
Don't Z06's have a tranny cooler and a tranny temp guage? Look into that, maybe they make an adapter or something for a fbody M6
Old Dec 30, 2003 | 06:02 AM
97FormulaWS-6's Avatar
It can be done with a small pump (one that wil take the temperatures) similar to what's used to pump rear axles for the coolers used on them, and a small AT cooler.... That and some Fittings/hoses and it can be rigged up... take the fluid out the drain hole, and return it on the fill hole...
Jxp
Aug 10, 2014 08:16 AM
Z28_LT4
Sep 6, 2008 09:13 AM
djk19
10
Jul 8, 2007 01:47 AM
ssscamaro
Oct 16, 2006 06:27 PM
96 trans am
Mar 11, 2006 12:49 PM
