LTX Removal Question
Old Oct 28, 2017 | 10:17 PM
snorkelface's Avatar
Because my car has a completely removable center center core support, it seems that it would be much, much easier to remove from the top as I have a ton of clearance in the front. I was planning on using this as it seems many have had consistent success with it:
https://www.tpis.com/parts/view/67
My question is, I have an auto; if I unbolt the tranny, will it stay in place since there's a cross member and tranny mount attached to it? I see where someone said I'd need to put a back under the tranny.
Old Oct 28, 2017 | 11:09 PM
Re: LTX Removal Question
The cross-member supports the tailshaft housing of the trans, way in the back. The engine supports the front of the trans. When you pull the engine forward, the front of the trams will drop, likely causing damage - cross-member, trans mount, or the tailshaft housing. Crib the front of the trans with stacked lumber.
Old Oct 28, 2017 | 11:35 PM
Got it! Thanks for the info!
