LTCC wireing help
Old Nov 27, 2003 | 10:36 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
LTCC wireing help
ok, somebody needs to write bob some instructions!!
on my 94, which wire on the ignition module goes to the white wire on the LTCC?
I have 1 yellow, 1 yellow/black, 1 black, 1 pink
?? no white as the instructions say.
help!
Old Nov 27, 2003 | 11:07 PM
InjectedSS's Avatar
Re: LTCC wireing help
help!
hahah oh man i feel sorry for you dude... I went thru hell getting that damn system to work. it looked nice once I got it INSTALLED but it never ran right so now im back to the good ol digital 7
refresh my memory on what it says the wires are supposed to go to... I know that one of the wires isn't listed on his instructions... Tell me what you got and ill get you some pics of what you need to do...
Old Nov 27, 2003 | 11:53 PM
Metlegleo's Avatar
Jordon,
I'll take a look at mine in the morning and post.
Mark
Metlegleo@aol.com
Old Nov 28, 2003 | 12:44 AM
bunker's Avatar
Ok well my kit had the right colors, it has the white, 2 pinks & 1 yellow.
But here is what I think you should do since I can help
Looking at the LTCC from the back where the wires go in & the mounting flages facing towards the bottom, the so called "white wire" would be the 6th wire counting from the right towards the center where the bolt is, that is the white wire. The yellow wire is the 5th wire counting from the right towards the center, the yellow wire is used for nitrous, the white wire plugs into the ignition module connector on the car's wiring harness which is the second one from either the left or the right, if you get the wrong one nothing will happen, but its the second one from either the left or right on the ignition module connector.
The other 2 wires are supposed to be pink & they aren't connected to the box connector, but instead just kinda run into the conduit of the ltcc, the two pink wires are connected together & both connected to one of the ignition coil's connector on the car's wiring harness.
Now to help you out, whatever the 5th wire on the LTCC connector is like I explained above, just don't use since its for N20. The 6th wire goes to the ignition module connector which is the 2nd slot from ither the left or right of the connector.
Man I'm repeating myself here
Good luck, if you need help PM me & I can go over it with you.
Old Nov 28, 2003 | 05:23 AM
arnie's Avatar
A search come up with this. Maybe this will help.
http://web.camaross.com/forums/showt...highlight=ltcc
maybe2fast
Apr 23, 2015 08:55 AM
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
