LTCC Rev Limiter & Stock computer
Old Mar 7, 2005 | 09:20 PM
Flyin_Z28's Avatar
I did a search and came up with nothing.
I'm wondering if anyone uses the uses the LTCC rev limiter or disables it.
Those who do use the limiter on the LTCC, how well does it perform in conjuction with the car computer rev limiter (re-programmed). Has anyone run into problems.
I was thinking of setting the LTCC box higher than the programmed computer rev limit or just set them the same.
Setting rev limit of computer to 6500rpm.
Also who uses the NOS retard control and how well does it perform?
TIA!!
Old Mar 7, 2005 | 09:49 PM
Boosted_Z28's Avatar
Re: LTCC Rev Limiter & Stock computer
I would suggest using the LTCC's rev limiter since it limits ignition spark rather the the stock PCM rev limiter which limits fuel. The PCM's rev limit rpm must be raised to a number higher that what the LTCC's rev limit rpm is set at by re-programming software.
canbaufo
May 25, 2015 12:01 PM
mikey4play
Mar 15, 2015 11:45 AM
armedtrigger
Feb 24, 2015 08:30 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
maybe2fast
Feb 5, 2015 05:14 AM
