LT4 setup,
Old Aug 19, 2003 | 09:20 PM
ramair94ta's Avatar
LT4 setup,
I have seen a lot of people talking about how great it is and the lowest i have seen the kit was 2200-2300.00. What is it , any pictures of it. what does the intake that comes with it look like ,is it the same as ours.
thanks for any help on this
Old Aug 19, 2003 | 09:29 PM
Summit has the kit in their latest catalog, with picture and parts list. The intake manifold is the GM LT4 red powder coated manifold. Looks the same as the LT1 intake, but powder coated red.
LT4 Intake
Although getting fully assembled LT4 heads, LT4 intake, the LT4 HOT cam and 1.6RR's in one neat package is convenient, you could probably achieve similar, if not better results with a good port job on your stock heads, and one of the popular LT1 aftermarket cams.
Old Aug 19, 2003 | 09:33 PM
ramair94ta's Avatar
i would really like to run in the low mid 12 by the end of the year and need to start on a set up soon.
thanks for the help
Old Aug 19, 2003 | 09:47 PM
TA Dreaming's Avatar
do a site search. there are a lot of posts on the LT4 conversion and lots of very good info. mids 12s is easily reached with that conversion, just use a ZZ9 cam and get the heads worked to accept it and your good. however you should be able to get in the mid 12s for a lot less than what the LT4 conversion will cost. Trey
Old Aug 20, 2003 | 07:41 AM
jim88iroc305's Avatar
Cool
I think I saw it on www.gmpartsdirect.com for 2,032.00
Don't know what the "infamous" shipping and handling would be on it, though.
I contemplated it when I blew a head gasket and warped my heads. Stock heads were $800.00 a head and AFR had a backorder of 8-10 weeks.
Wound up finding a set of mildly ported Corvette LT 1 heads for $200.00 here which did the trick.
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
