LT4 KM You got to get one
Old May 1, 2004 | 10:18 AM
  #16
snksknr94's Avatar
Originally posted by Josh-'97 WS6
Completely incorrect. Headers, as well as roller rockers, can create resonances that are sympathetic to the stock KM tuning and can trigger false knock. The LT4 had a noisier valvetrain due to increased cam ramp rates in addition to roller rockers. The LT4 KM is simply better tuned to pick up real detonation, and filter out some issues with a modded engine. Just because the LT4 KM does a better job of narrowing in on real detonation doesn't mean you "have a serious problem with there (sic) motor."
Thats what I said, "all it does is eliminate some frequencies that could be considered knock with the factory KM, such as roller rockers." I don't think I did a very good job of explaining the other part of my post. If someone sees a huge gain with the addition of the LT4 KM they could have a problem. The LT4 KM is not as sensative meaning it picks up less knock related frequencies, if you were having quite a bit of timing pulled due to the LT1 KM picking something up, then switch to the LT4 KM and it goes away. Rather than mask the problem I'd like to know what was causing it, so it doesn't do any harm to the investment under the hood of my car. Hopefully that clarifys what I was trying to get across, and small gain will be seen, especially if car is equipped with roller rockers, or something else that is causing false knock. I personally would just like to make sure that it is indeed false knock before I go and mask what could be a major problem.
Old May 1, 2004 | 01:08 PM
  #17
joeSS97's Avatar
Originally posted by snksknr94
Hate to break it to you but the LT4 KM does nothing to change the sound of your exhaust. All it does and eliminate some engine frequencies that could be considered knock and that could cause timing to be pulled, such as roller rockers. It also has nothing to do with eliminating a miss or making your car run any cleaner. Anybody who sees a huge gain with the LT4 KM has a serious problem with there motor, because now what could have been a real problem is being masked, and could lead to engine problems down the road if your motor really is knocking.
I have to disagree.Having KR will increase the amount of unburned gasses in the exhaust,causing more popping.
Old May 1, 2004 | 06:52 PM
  #18
CamaroSS30thAnn's Avatar
well then which is it......im planning on getting Pacesetter long tubes......
get or not to get the LT4 KM?
Old May 1, 2004 | 06:57 PM
  #19
StickMaster's Avatar
Def. Get it
Old May 1, 2004 | 07:55 PM
  #20
snksknr94's Avatar
Thats kinda proves my point. If your getting enough KR with the LT1 KM to be running that rich that you are getting popping from unburned gas in the exhaust, then you have a problem that needs to be addressed, not just masked by tricking the PCM with the LT4 KM.
Old May 2, 2004 | 08:34 AM
  #21
Josh-'04 GTO's Avatar
I think you're on the right track, but you're not "tricking" the PCM by getting an LT4 KM. It just does a better job of picking real detonation in a noisier engine. That is good thing! False knock can rob you of 30 horse in a hurry-I found out the hard way in my last car's stroker. There was no major problem covered up. It was just false knock.
Old May 2, 2004 | 01:10 PM
  #22
snksknr94's Avatar
Basically thats what I'm saying. If it is for sure false knock then it is an absolute must have. However, it has been my understanding that the LT4 KM isn't doing a better job at picking up real detonation but that it isn't as sensitive and may not sense real detonation, whereas the LT1 KM is more senstive which is why it picks up more false knock.
Cliff Notes: If you have issues that are for sure fasle knock go for the LT4 KM. If you aren't sure if it is fasle or not, verify that before adding the LT4 KM.
Old May 2, 2004 | 01:30 PM
  #23
are there any advantages of the LT4 KM on a almost stock car or say what i have in my sig except for the headers.....
not saying this is my reason but my LM does pop alot when its cold....could this be one of the reasons......or is it jut b/c the LM is that raspy and poppy?
Old May 2, 2004 | 01:36 PM
  #24
Bersaglieri's Avatar
I got one for my GMMG, just incase, and now that I have Hookers to put on I am glad its already there.
Get one CamaroSS30thAnn, it doesnt hurt to have. Unless you already have a knock and its real. But I dont think you do.
The LM popping is just cause it pops. An engine knock you'll hear from the engine like a knocking sound. Its kinda hard to explain. Plenty of guys use them on here with no problems epsecially with headers and loud exhausts.
-Dustin-
Old May 2, 2004 | 01:43 PM
  #25
snksknr94's Avatar
Your popping is just from the LM, I had one for a while I had to get rid of it, started to annoy the hell out of me.
Old May 2, 2004 | 04:36 PM
  #26
Eff's Avatar
Eff
just curious, does anyone know what considered
the safe upper limit for knocking in a camaro
Old May 2, 2004 | 05:39 PM
  #27
Antz97ZNJ's Avatar
Thumbs up
Had one on my old 97...didnt get any faster but definately had a smoother top end
Old May 2, 2004 | 05:45 PM
  #28
im getting one they are only like 30 buck i think on gmparts direct
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
