LT4 intake manifold
Old Jun 24, 2005 | 09:11 AM
1crazylt1's Avatar
LT4 intake manifold
Would you feel a difference in a 1994 chevy camaro lt1...if you put an lt4 manifold on thier?
Old Jun 24, 2005 | 10:18 AM
teke184's Avatar
Re: LT4 intake manifold
LT4 intake will not bolt onto lt1 heads...ports and angles are different i beleive.
there isn't much hp to be gained in them, it's just that they are different to accomodate the different heads.
so don't worry about it
Old Jun 24, 2005 | 11:12 AM
1crazylt1's Avatar
well i was goin to get the lt4 manifold from summit that fits the lt1
Old Jun 24, 2005 | 12:45 PM
Go back and read what the Summit catalog says... doesn't say it fits the LT1.... it says its works with the things that attach to the LT1 intake (like the sensors, throttle body, etc.). Click on the part # and if you read carefully, at the bottom you will find:
Requires LT4 cylinder head conversion.
Lets try it one more time... the LT4 intake manifold will not bolt to LT1 cylinder heads, unless the intake or the heads are modified to eliminate an interference between the top of the LT4 intake runners and the valve cover support rail on the LT1 heads.
After spending $200+ for the intake, and then having it machined, you can bolt it up. The gains from this will be approximately "0" HP. Although the intake runners of the LT4 heads is 0.100" taller than the ones in the LT1 heads, the LT1 and LT4 manifold runners are virtually identical. There is no difference in the openings... the LT4 intake simply has more metal at the top of the runner so they can be ported to match LT4 heads. The LT4 intake doesn't match thte LT4 heads as shipped from the factory.
All of this has been posted many times and could have been found with a "Search"
Old Jun 24, 2005 | 02:13 PM
Est96Z28's Avatar
Like said above, waste of time and money.
Old Jun 24, 2005 | 03:25 PM
1996LT1NY's Avatar
So are you saying it is not worth it?
Sorry.... warped sense of humor getting the best of me today
Old Jun 24, 2005 | 08:40 PM
97WS6SCharged's Avatar
But the red manifold looks nice.
Old Jun 24, 2005 | 11:15 PM
Yep... specially with a little bit of aluminum polish on the fuel rails.....
http://cjcfo.fbody.com/members/injun.../DCP04252a.jpg
Old Jun 24, 2005 | 11:27 PM
I know what you mean. http://community.webshots.com/photo/...65054499BDeYjW
What kind of fitting did you use in the fuel rail cross over pipe for the return?
Old Jun 25, 2005 | 07:50 AM
Its a cut down stub of a -6AN fitting welded to the cross-over tube.
http://cjcfo.fbody.com/members/injun.../DCP04272a.jpg
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
