LT4 hotcam valvetrain... LE1 cam Approved?
Old Nov 19, 2006 | 02:20 PM
aaron_depue's Avatar
As the title implies.... I am wondering if the valvetrain components found in my GM LT4 hotcam kit will be a safe combination with a Lloyd Elliot cam? I know combination motorsports recommends a bunch of comp cam valvetrain components. I am currently running the LT4 hot cam and I am wondering if I decided to switch and go with a cam from Lloyd, would I need to buy all new drivetrain parts? Or will the ones supplied from my LT4 hot cam kit be sufficient? Also what about the LE1 Heads? Will I need to switch out any additional drivetrain parts when I get my heads ported? I am curious to hear you guys thoughts about this topic. Any replies will be appreciated
Old Nov 19, 2006 | 02:23 PM
MeanGreen97Z's Avatar
Well from what I understand the LE1 cam has more lift and duration that the hotcam. No one but LE1 cam owners know the specs but I can assure you that they wouldn't recommend the springs that they do if it didn't need them. You can use your 1.6 rockers but not the springs.
Old Nov 19, 2006 | 02:55 PM
wrd1972's Avatar
The LE1 cam has a bit more lift and will not work with LT4 springs. Once you by the cam he will give you the specs. I have the LE1.5 cam which has even more lift than the LE1.
Old Nov 19, 2006 | 08:52 PM
96capricemgr's Avatar
The GMPP rockers are also lift limited compared to most other roller rockers so make sure you tell him you want to use those and he can tell you if the cam they have in mind falls within that lift limit which is I think .550.
Old Nov 19, 2006 | 10:44 PM
Ya .550 sounds right... I was thinking .560 but .550 sounds right.
Old Nov 20, 2006 | 01:06 AM
seawolf06's Avatar
I'm gonna go out on a limb and say no freakin way. The springs alone are barely enough for the hotcam which has very little lift compared to what most cams around the LE1 have. You really need to call them and ask. I don't understand why everyone asks questions like this on the forum instead of just calling the place of business.
GigaMp3z
Feb 20, 2003 02:57 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
