Electric Water Pump Questions??
Old Nov 19, 2006 | 09:13 PM
3_z28camaro's Avatar
Hey guys. I searched the old threads but I could not find anything that answered my question. So here is goes.
My 1994 Z28 has always had cooling issues. Mainly under more stressful conditions like uphill, lower speed, on a 100+ summer day or in traffic the thing gets too hot. Meaning having to pull over and wait for it to cool off because it was in the red. I have the manual fan switch so I can have the fans on high all the time and the radiator in clean and fairly new.
So my question is to those that have put electric water pumps in their LT1's, do they significantly lower the engine temperature? Also, if you used one what manufacturer do you recommend?
Thanks!
Old Nov 19, 2006 | 09:24 PM
jay_lt4's Avatar
figure out why your car is overheating, a electric water pump is nice but not a cure for an overheating engine
it should not get in the red on the gauge, if your running the fans on high and it still overheats you have problems
Old Nov 19, 2006 | 09:26 PM
Javier97Z28's Avatar
Moderator
Agreed, EWP won't fix whatever problem it is you are having.
wrd1972's Avatar
What he said
Old Nov 19, 2006 | 11:31 PM
Hmm, in that case, have any suggestions what the problem might be?
Radiator close to new
Coolant level always full
Fans on high
Those things aren't the problem.
Thanks.
Old Nov 20, 2006 | 01:11 AM
zx1216's Avatar
There is probably air in the system, it needs to be pressureized to increase the boiling point of the coolant, if there is air in the system this will not occure. Do a search for bleading the system and you should find how to do it. if this doesn't work check your thermostat, put it in a pot of water and see what temp it opens at.
Old Nov 20, 2006 | 01:14 AM
LT1 POWR's Avatar
Hows your thermostat, is it LT1 specific, and what temperature is it? Are you sure you dont have any air in you cooling system? How old is your coolant, and what type/mixture are you useing? Are you sure your water pump and fans are working propery? Just some things to thing about.
Old Nov 20, 2006 | 01:38 AM
I have done all sorts of things with the thermostat. I have replaced it several times, I have tried no thermostat (that was a test). I think it is in the range of 160-180 degrees, I think. I have to check the records on that. I always do check my thermostats in the boiling pot of water. I am quite sure there is no air in the system, I bleed the thing whenever I mess with it. The mixture is not all that well balanced. But the fluid in the system is fairly fresh. My fans work I can hear them both going.
The water pump was replaced also, that was a while ago, yet it had the problem before and after.
The issue really only shows up when I am stuck on traffic or a slow uphill climb during really warm weather. The way is reacts though is just not right.
Thanks for the ideas guys, I can check into some other things that your suggestions made me think of.
Old Nov 20, 2006 | 01:50 AM
zx1216's Avatar
huh, thats wierd man, i ran a 160* stat and in 90* weather it never went over 180-190... how about your emissions stuff? I'm not really sure if that would cause a big difference in operating temperature since i don't have that stuff anymore, haha, good luck!
HectorM52
Jul 30, 2017 11:46 AM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
