LT4 Hot Cam vs Comp XR270
Old Jan 14, 2013 | 05:12 PM
12Second3rdgen's Avatar
I decided to post this here as I thought the LT1 crowd might know a bit more about the hot cam than some others. Basically, I have found that I can get an LT4 hot cam reasonably cheap either used or new. The Comp XR270 is much more expensive and harder to find used.
I figured these two cams would be within 5-10 horsepower of each other in Desktop Dyno. Plugging the two cams in, I came up with the following numbers:
LT4 Hot Cam:
XR270:
Now I am not running EFI, I am putting this cam in a 350 with Vortec heads and 9.5:1 with a 650 double pumper. If the difference is 10 horsepower and 10 ft lbs, I could care less about spending the extra $$$ getting the comp cam. It appears that the XR270 in desktop dyno is making an extra 35 horsepower and 40+ ft lbs, that is a HUGE difference which is why I don't think that's right. I thought I would ask the knowledgeable folks here to double check though .
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
