LT4 Hot cam with LT4 valve springs...
Old 08-01-2003, 05:48 PM
craigffb's Avatar
Anyone running this combo? If so, any problems with valve float?
Thanks,
craigffb is offline
Old 08-01-2003, 06:07 PM
Camaro_Maniac63's Avatar
I run that combo, and I don't have any valve float, but then, I still use the stock programming and the stock redline. I don't know if there will be any valve float over 6k rpm.
Camaro_Maniac63 is offline
Old 08-01-2003, 06:15 PM
96speed's Avatar
Smile
Get some springs that were made for the job. People assume "LT4 springs" are complementary with "LT4 HOTcam" - untrue.
The LT4 springs are designed for use with the LT4 cam, not the HOTcam. The LT4 springs work good for someone looking to go with a 1.6 rocker on a stock cam because of their price and availability.
Ryan
96speed is offline
Old 08-01-2003, 08:12 PM
craigffb's Avatar
I don't really want to change the springs again. Is there any gain to be had from the LT4 cam?
craigffb is offline
Old 08-01-2003, 08:16 PM
Z95m6's Avatar
the LT4 cam isn't going to have any gain over the stock cam
Z95m6 is offline
Old 08-01-2003, 08:20 PM
craigffb's Avatar
So let me get this strait. The Hot cam kit comes with LT4 springs, but aren't the right spring rate for the cam. Or does the Hot cam kit come with different springs?
craigffb is offline
Old 08-01-2003, 09:03 PM
gb95zconv's Avatar
Those springs will be fine if you dont plan on spinning the engine up over 6200rpms or so. They arent the best but they are adaquit. I ran that combo without a problem for a while.
gb95zconv is offline
Old 08-01-2003, 09:34 PM
vodoo-chile's Avatar
I run the springs with kit and have custom programming with shifts at about 6200 rpm. Not a lick of problem.
Kyle
vodoo-chile is offline
Old 08-01-2003, 10:38 PM
craigffb's Avatar
Kyle
Kyle,
Do you by any chance remember what the part number was for the 94 cam, also what else would I need besides the cam and some programming to do the install? I all ready have the rockers and springs in the car.
craigffb is offline
Old 08-02-2003, 07:55 AM
Originally posted by craigffb
Kyle,
I'm sorry I don't know the part #. I just bought the entire Hotcam kit as a whole. I thought that the cam was the same, 95+ with longer dowel, and if you were going to stick with the non-vented 93-94 Opti, you just needed to ground down the dowel or have it pushed in some. I'm not sure. Some precautionary items I replaced while it was done was new timing set and new Opti. I went with a stock timing set and my Opti had 80+k miles on it. You may want to consider just swapping to a 95+ vented Opti since they are cheaper anyway and you wouldn't have to worry about the cam dowel problems. I also use a mail order tune from Bryan @ PCMforless and he has it pretty much dialed in for the Hotcam. I drive mine everyday, putting about 75 miles/day and it runs like a champ. If you have any other questions, feel free to ask. Good luck,
Kyle
LeftoverChinese
01-14-2024 03:03 PM
djangoroar
Parts Wanted
02-21-2015 11:47 PM
GigaMp3z
02-20-2003 02:57 PM
Speeds8erM-1
07-28-2002 06:18 PM
Speeds8erM-1
07-18-2002 11:36 PM
Quick Reply: LT4 Hot cam with LT4 valve springs...
