LT4 AFR heads
Old Apr 27, 2006 | 10:06 PM
sleeperMULLET's Avatar
LT4 AFR heads
Hey guys, i'm in the process of building a 383 LT1, but i'm still unsure of what heads i'm going to run. I would like to use the AFR 215cc LT4 heads. I know I will need the LT4 intake, but if i run that intake and heads will that change any accessory location, like the alternator, power steering pump, etc....Also are the PVC, vaccum lines, and EGR still in the same spot on the LT4 intake? And will the fuel rails from the LT1 work on the LT4 intake. Do I need a different timing cover, do I have to use a LT4 timing chain, there are so many questions I have. Has anyone run these heads with the LT4 intake?
Old Apr 28, 2006 | 05:27 AM
Re: LT4 AFR heads
has anyone here done the LT4 swap? Do all accessorys stay in the same spot?
Old Apr 28, 2006 | 07:49 AM
96capricemgr's Avatar
Re: LT4 AFR heads
You are grossly over complicating this. All accessories are fine, LT1 timing chain is fine but with an electric waterpump you could use a Gen 1 timing set.
The only real differences in the LT4 intake are it is red and there is more materila above the port to seal to the taller LT4 ports. Notice I said more material. The plenum and ports are the same and located the same as an LT1 intake, if you want one to match LT4 heads you need to have it ported. That said they are no longer available new so the used price as gotten really stupidly high. Might look into having material welded on top of the ports of an LT1 intake then having it machined true again and porting that, likely cheaper than an LT4 intake at this point.
Old Apr 28, 2006 | 10:27 AM
Ram Air 383's Avatar
Re: LT4 AFR heads
LT4 intake will not match up to AFR 215 heads due to raised ports. You will need to use spacers or get a custom intake.
AFR 210/220/227 will work.
LeftoverChinese
Jan 14, 2024 03:03 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
