How Hard To Remove Pass Side Header?
Old Apr 27, 2006 | 11:15 PM
mooner's Avatar
Question How Hard To Remove Pass Side Header?
I have a crack in my pass side header and want to know how hard it would be to remove. I had then installed so i dont know.
Old Apr 28, 2006 | 04:36 AM
MeanGreen97Z's Avatar
Re: How Hard To Remove Pass Side Header?
What kind of headers? Longtubes are a little bit of a PITA but shorites are too easy.
Old Apr 28, 2006 | 05:05 AM
lt11997's Avatar
I think he means his stock manifold, which isn't hard at all. It's been awhile so I don't remember if comes out through the top or bottom.
Old Apr 28, 2006 | 07:10 AM
I took out both through the top. Unbolting that stock rusted y pipe is the hard part.
Old Apr 28, 2006 | 10:04 AM
2000GTP's Avatar
If its a stock manifold, it will come out right through the top, its not that hard. If its a long tube header, you may need to remove the valve cover to gain a little extra clearance to pull it out.
Old Apr 28, 2006 | 10:10 AM
ttop1986's Avatar
I dont think hes talking about stock manifolds, because he said he had them installed. So why would he have stock manifolds installed. Anyways if they are long tubes, youll prolly have to jack up the motor to pull it out the top. Also take the valve cover off like 2000gtp said. The pass side is the bitch of the 2. My driver side was 10x's easier, but i was putting them in, had to make them fit right. Taking it out will be alot easier.
Anyone correct me if im wrong, but to get the valve cover off, you gotta take off the serpentine belt, and altenator. (at least it would be a hell of a lot easier putting the valve cover back on.)
If you jack the motor, and take the valve cover off, they header comes out pretty easily, i had to do this a bunch of times while installing mine.
Old Apr 28, 2006 | 10:19 AM
mooner's Avatar
Question Re: How Hard To Remove Pass Side Header?
It is a header i bought it from the guy who put it in and it has a crack. i need to remove the header to fix crack. it is a long tube header.
Old Apr 28, 2006 | 10:28 AM
2000GTP's Avatar
Yes, you are right, taking of the serp. belt and alternator is part of the chore as is disconnecting the AIR line if the header is equipped with the AIR fitting.
DirtyDaveW
Dec 1, 2016 05:37 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
