Lt4
Old Nov 27, 2004 | 11:05 PM
camarokidirocz's Avatar
Exclamation Lt4
does anyone have an lt4 upgrade like the whole kit intake, cam etc and if so how much power do u make?
Old Nov 27, 2004 | 11:09 PM
djfuzzy's Avatar
Re: Lt4
Yes.
http://www.gmpartsdirect.com/results...ber=pk12550630
Old Nov 28, 2004 | 02:19 AM
Z95m6's Avatar
Re: Lt4
Most people don't really run the complete LT4 conversion. The reason they don't is what you'll pay for the LT4 conversion you could get your stock heads ported,a much better cam, and make way more hp than the LT4 setup. The ported stock heads and better cam would probably cost less too.
Old Nov 28, 2004 | 09:33 AM
T/A#4's Avatar
Re: Lt4
This subject keeps coming up so lets bury it once & for all with facts & not rumors. For the dyno results on the LT4 heads & then cam swap go to:
www.moreperformanceinc.com
Old Nov 28, 2004 | 10:13 AM
tonylittell's Avatar
Re: Lt4
can you get better flow from a set of lt4 heads that have been ported than you can get from a set of lt1 heads with the same porting work?assuming all veribles are the same such as shop doing the work and flow bench ect.and both sets have been ported to their max capibilities
Old Nov 28, 2004 | 10:44 AM
T/A#4's Avatar
Re: Lt4
Per the above articles: the LT1 heads have 170 cc ports verus the 195cc LT4
ports. So using these sizes as a starting point it becomes obvious that 25 cc [.100] is a nice increase. Note that these sizes are the for full lenght of the port. I was shown the diff at a locl head porting shop & was suprised that the diff was so great. When you look at the port from the outside top of the head you notice the diff as the port passes the valve spring seat. No to mention the diff when you compare the intake gaskets. Remember we are talking "starting points" here.
Old Nov 28, 2004 | 11:14 AM
Re: Lt4
hummm i may get me a set of lt4s and port them instead of waiting 3 months for the afr heads...i know i wont get afr numbers but i should be able to get a few more cfm out of the lt4s...maybe i should look a little more into it...thanks man
Old Nov 28, 2004 | 12:10 PM
T/A#4's Avatar
Re: Lt4
AFR 195 heads = 195cc intakes. Look around for a used pair of LT 4 heads at your local head porter. Or post a wanted to buy post here. Thats what I did.
Or you can get a new pair for GOLAN ENGINES for $900. What I like about these heads is the Sodium filled intake valves, so light you won't belive it .
I had the CompCams Bee Hive valve springs installed, this setup should be good to 6800+ rpm.
Old Nov 29, 2004 | 01:46 PM
Re: Lt4
thanks man...think im gonna go the lt4 head rout...should save me some time and money over the afr heads and get camparable results
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
