LT1 wont be going to the dyno anytime soon.....
Old Mar 11, 2011 | 10:53 AM
SmartOJ's Avatar
so could you guys help me out.i wanted to see if anyone had a similar setup to me or if some of you gurus could do a good guesstimation on how much hp and torque im possibly making at the wheels.its a pretty simple setup nothing spectacular...i have..
stock bottom end & untouched stock heads
comp cams xe 230/236 112
crane 1.6rr
k&n cai
ebay headers and y pipe
"flowsound" muffler & electric cutout before axle
pcm has been tuned
what kind of hp and torque u think im making at the wheel?
thanks
Old Mar 11, 2011 | 01:41 PM
95mysticta's Avatar
Re: LT1 wont be going to the dyno anytime soon.....
A4 or T56? Do you have a bigger stall converter in there and a bigger rearend? Id guess if its an A4 its in the 330-340 range and if its a T56 340-350rwhp. Pulling the heads and putting in a impala head gasket will bump the compression up will help alot.
Old Mar 11, 2011 | 07:34 PM
SmartOJ's Avatar
car is a 96 z28 m6 with the stock 3.42 gears.i just want to get a "idea" on my hp range.and then maybe try to max out the power as much as i can before i start touching the heads and shortblock
Old Mar 11, 2011 | 07:47 PM
Procharged94Lt1's Avatar
You will be better off if you can get to a track and follow your improvements there. There is no standard from one dyno to another and your car can show different readings even on the same dyno depending on who is running it that day.
Old Mar 11, 2011 | 08:04 PM
my1994z28's Avatar
Without any head work,I would guess your around 300 rwhp..
Old Mar 12, 2011 | 08:54 AM
Kevin Blown 95 TA's Avatar
I would guess that as well if it's healthy and assuming good valve springs.
Old Mar 29, 2011 | 02:50 PM
RealQuick's Avatar
should easily hit 330rwhp with mailorder tune. Squeak a few more ponies with a dyno tune.
I made 383rwhp/353rwtq with the same cam and a set of LE2 ported heads done 8-9 yrs ago. I was on a mailorder tune that I tweaked the A/F on.... never tweaked the timing.
Old Mar 30, 2011 | 12:13 AM
jethrobodean's Avatar
Didnt 96 M6's come with 3:73 from the factory?
Old Mar 30, 2011 | 12:37 AM
ACE1252's Avatar
'93 - 3.23
'94 and up - 3.42
Old Mar 30, 2011 | 05:14 AM
Actually 93 M6's came with either 2.73 or 3.23. After that, all M6's were 3.42.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
cheapchevy
Apr 8, 2015 08:48 PM
jayblev95
Dec 1, 2014 06:55 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
smacz28
Aug 6, 2002 01:51 PM
