LT1 Wiring Harness in S10
Where can i find the info on Which wires will i need to connect to my wirring harness from a 93 Z28 LT1 to a 89 S-10 2.5 harness! andy information will be helpfull!!
greg
greg
Try JTR. They have a conversion manual for V8's in S-10. It cover just about everything.
http://www.jagsthatrun.com/
checkout the V8 Tech forum at www.s-series.org
I used a Helms Shop manual for my 94 motor and a Haynes repair manual for the truck wiring. I just found all the powers, grounds, inputs, outputs, and gauge wires I needed and went to town on it. Also, Shoebox has a wicked site w/ the pcm pinouts and basic wiring diagram to get you started, that is mainly what I used till I won my set of manuals off of ebay.
You might want to check out the v8 section on www.s-seriesforum.com, there are a bunch of guys that have done the swap as well as informative posts, part numbers, and fubars to look out for. I'm Hotwire on there as well.
I'm loving mine, doing a LT4 conversion as we speak.
Good luck.
Good luck.
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
