LT1 will start and die...is it IAC
Old Sep 3, 2003 | 01:55 AM
Twice The Fun's Avatar
i ahve check fuel pressure and its good, fuel pump is fine (dyno afr showed to be 13.0 - 12.0, so im not lean in any way)
i was told to check the IAC, i did, and then cleaned it with only a shop rag to get the tons of build-up off of it.,.....this fixed it for a few days, now its back....just wanted some advice from people who have had this prob b4 thanks
Old Sep 3, 2003 | 03:33 AM
Est96Z28's Avatar
Cleaning it will not always work, get the new one and forget this problem. I did so ...
Old Sep 3, 2003 | 12:32 PM
Thanks for the replies, cleaning it was only a temp solution, gonna go ahead and replace it
Idle Air Control = IAC
Old Sep 3, 2003 | 09:56 PM
BigEvil's Avatar
You've got the right idea/info. Replace it.
Old Sep 5, 2003 | 01:55 PM
for anyone have this problem........the IAC is a possible culprit....it fixed my problem!!!
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
