LT1 will start and die...is it IAC
i ahve check fuel pressure and its good, fuel pump is fine (dyno afr showed to be 13.0 - 12.0, so im not lean in any way)
i was told to check the IAC, i did, and then cleaned it with only a shop rag to get the tons of build-up off of it.,.....this fixed it for a few days, now its back....just wanted some advice from people who have had this prob b4 thanks |
Cleaning it will not always work, get the new one and forget this problem. I did so ...
Thanks for the replies, cleaning it was only a temp solution, gonna go ahead and replace it
Idle Air Control = IAC |
You've got the right idea/info. Replace it.
for anyone have this problem........the IAC is a possible culprit....it fixed my problem!!!
