LT1 will not run. Help.
Old May 4, 2006 | 08:52 AM
Rage's Avatar
I have installed a LT1/T56 in my 87 Camaro. Everything is connected except for IAC and the car will not run. I am getting spark, compression, and fuel, and the car will crank, start for about 5 seconds and runs only if it is at WOT, and then dies the when I back off the throttle.
Where is the VATS 16 pin connector? I cant find it. That may be a problem. I dont know.
Anybody ever had similar problems?
Old May 4, 2006 | 09:02 AM
Honda Hunter's Avatar
Re: LT1 will not run. Help.
Dont you need the iac to idle?
Old May 4, 2006 | 09:45 AM
Rage's Avatar
Sorry, it's the IAT that isnt plugged in, not the IAC. Sorry.
Old May 4, 2006 | 09:48 AM
If all else is fine I would have to blame the iac. would adjusting the t/b screw help?
Old May 4, 2006 | 08:53 PM
Rage's Avatar
I dont think so, because like I said, even when it does run, it runs like crap, so I dont think that would help. Im kinda loosing my patience with the car. Do you think a ball-peen hammer might take care of it?
Z28countrymama
Jan 22, 2015 02:50 AM
jayblev95
Jan 20, 2015 01:30 PM
1775.Z28
Jan 11, 2015 10:51 AM
Victory Racing
Sep 1, 2002 06:05 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
