LT1 Weaknesses
Old Oct 20, 2004 | 03:44 PM
  #61
Jerm's Avatar
From: You know when they Quit Suckin that something is Wrong!!!!
Re: LT1 Weaknesses
Originally Posted by chrism400
Yes I would agree. I didn't know the advertised duration of the Hotcam and still don't (trying to find that out.) If the advertised duration at .006 is more than the XE grind, then overlap can be more depending on valve opening and closing events. As far as I can see, Z95M6 may be right on this one. But I wouldn't say I'm your "Bitch" though. The score is 2-1 in my favor. Shame on me for not checking the advertised duration on the Hotcam.
Cam help for Z95M6, Jerm, & chrism400 :
Since we talking degrees, I might as well cover duration. Duration is the amount of time that the valve is open in relation to crankshaft rotation. It is expressed in crankshaft degrees. If we have a cam with a duration of 300 degrees, the valve will be open for 300 degrees of crankshaft rotation. There are two methods used to describe duration. Seat-to-seat or Advertised duration and at .050" duration. The advertised duration is the measurement from the very beginning to the very end of the lobe ramps. It is difficult to get an accurate measurement using advertised duration. Theoretically, you should be able to find zero lift of the lobe ramps, but it is harder than it sounds. To simplify this method, cam grinders pick an arbitrary number unique to themselves. It could be anywhere from .002" lift to .008" lift. Because cam grinders wont get together and give us consistent advertised duration lift points, they came up with a standardized method of @.050" lift. When the lobe is at .050" lift, the duration starts and ends when the lobe is at .050" lift on the other side of the lobe. When comparing cam profiles, it’s best to use the .050" duration numbers.
Duration is probably the most important aspect of a cam’s profile to pin down when selecting a cam. Cubic inch displacement, cylinder head characteristics, EFI, NOS, aspiration, compression, drive train, vehicle application and weight, desired peak power, desired engine operating rpm…….etc are all factors to consider when picking a cam. I’ve found that it’s usually a task best left to the cam grinder to make. I’m not going to get into cam selection in this article, but I should talk a bit about the effects that duration has on an engine.
The advertised duration is listed at .050" on every cam I've seen, how are you supposed to find that out?
I'm lost
Old Oct 20, 2004 | 03:51 PM
  #62
WS Sick's Avatar
Re: LT1 Weaknesses
I'm lost
They used to list the advertized duration numbers at like .001 lift in the old days only. The manufacturer will have the full specs of the cam.
Old Oct 20, 2004 | 04:05 PM
  #63
WS Sick's Avatar
Re: LT1 Weaknesses
Originally Posted by TQdrivenws6
That is not necessarily true. Overlap is affected by the opening and closing rates also, so if the valve timing is more or less aggressive around the seat, then you can have the overlap change also.
I can't understand what youre saying here, please explain in simpler terms for me please .
The way I understand it if the valve opening and closing points are identical (same adv duration on the same LCA) the open period would be the same reguardless and thus the overlap would be identical ,for instance if both cams open the intake at say 20 BTDC and both close the exhaust 15 ATDC and they both have a 110 LCA but one has 230 .050 and the other has 224 .050 they would both still have 25 degrees of overlap right?
Old Oct 20, 2004 | 04:10 PM
  #64
TQdrivenws6's Avatar
Re: LT1 Weaknesses
I was refering to a situation where opening and closing points are fixed, but the ramp rates are different. I have generally seen overlap referred to as deg @.050" lift. The cam with more aggressive ramps will get to the .050" lift sooner than the cam with the lazier ramps. So a smaller lobe with more aggressive ramp rates can have as much overlap as a larger lobe with lazier ramp rates.
Old Oct 20, 2004 | 04:13 PM
  #65
WS Sick's Avatar
Re: LT1 Weaknesses
Ok I see what youre saying. Thanks for explaining.
Old Oct 20, 2004 | 08:57 PM
  #66
chrism400's Avatar
Re: LT1 Weaknesses
Originally Posted by Z95m6
See obviously you need to look at some cam specs. The Xe's have more duration at .05 lift but actually have less advertised duration. So actually the lobes are smaller than a standard lobe of similar duration at .05 lift. They just spend more time at higher lifts so they make more power from a smaller lobe. Look at just the intake lobes. The hot cam intake lobe has 280 degrees of advertised duration vs the 224's intake lobe of 276 degrees of duration. Hmm it seems the hotcam's lobes are bigger. Even though the 224 has more duration at .050 lift. What did i tell you the Xe lobes are actually smaller than standard lobes yet they make more power. You said in your own post that more duration = more overlap. Read, learn, understand what you are talking about before you post. You are Owned B!tch.
You still aren't off the hook yet. You may have gotten lucky on this one but I have yet to find what "lash point" means. This is supposedly how GM came up with their so called advertised duration. I called Comp Cams cam help to get an explanation on this and he has never heard of it either. He suggested that maybe it means lash ramp to lash ramp. In other words, .000 to .000 and not .006 like most manufacturers do. Here is an example: The Edelbrock cam for LT1 has an advertised duration of 288/288 but duration at .050 is only 218/218. How are they measuring their advertised duration? Is it "Bigger" than both the Hotcam and the XE 224/230? I think not. I have an Ultradyne solid roller in my 406 that says advertised duration is 294/298 with duration of 263/267 at .050. I guarantee that cam had more than 6 degrees of duration than the Edelbrock LT1 cam! Does this mean that the Edelbrock cam is super, super lazy? Advertised durations are measured in so many different ways and are intentionally confusing. I'm still not convinced that the Hotcam even though it has only 218/228 deg duration at .050 actually has more duration than the Comp XE 224/230. Heck, guys are saying the Hotcam is a 112 LSA when mmy buddy has a sheet that came with his Hotcam that said it had 112 intake lobe centers, 114 exhaust lobe centers with a 114 LSA!!!!!!!!!!!!!!! I don't think anyone really knows what the heck the Hotcam really is. Still doing research...
Old Oct 20, 2004 | 09:30 PM
  #67
Z95m6's Avatar
Re: LT1 Weaknesses
The Xe lobes are designed to do more in a smaller lobe. Ex. CC306 intake lobe VS 230/236 intake lobe.
.050 duration Advertised duration
CC306 intake 230 290
230/236 intake 230 281
Since both of these are Comp Grinds they would be using the same measuring devise (tolerances) to measure the Advertised duration. The Xe lobe still has smaller advertised duration so it will provide less overlap provided the exhaust lobes were the same size. I believe i remember Phil at AI telling me that you can look at the Advertised duration vs the .050 lift to see how aggressive the ramps were. I wanted a lunati 227/233 cam instead of the XE but he said the ramps were so big and lazy by comparing Advertised duration vs .050 duration, that it would have overlap like the CC306. So i went with the XE grind instead.
Old Oct 20, 2004 | 09:44 PM
  #68
chrism400's Avatar
Re: LT1 Weaknesses
[QUOTE=Z95m6]The Xe lobes are designed to do more in a smaller lobe.
Yes, I get that much. It's good to have a shorter duration lobe with high ramp rates to open and close the valve quickly. It lets the engine get the job done with less cylinder pressure loss etc...I'm unsubscribing to this thread because I haven't eaten in 4 days, my hair is falling out, the wife says I'm ugly, and my kids don't recognize me anymore. I just don't care anymore and I think my life is over.
Old Oct 20, 2004 | 10:45 PM
  #69
turbo_Z's Avatar
Re: LT1 Weaknesses
24502586 Hydraulic Roller (LT4 Hot Cam)
This hydraulic roller cam is for service only for all V8 engines with roller camshafts. The duration at lash point in degrees (intake/exhaust) is 279/287; duration at .050" tappet lift (intake/exhaust) is 218/228; and maximum lift with 1.6 rocker ratio (intake/exhaust) is 525/525. Valve lash is zero/zero and lobe centerline is 112 degrees.
I got the specs from the gm goodwrench website. Are you a believer now?
Old Oct 21, 2004 | 10:18 AM
  #70
Jerm's Avatar
Re: LT1 Weaknesses
I went on the Canton site for an oil pan and came across a few things regarding the oil pan for the 96 LT1 fbody.
STYLE: 7-1/2" shallow, fully baffled for road racing, this pan was designed to fit in late model (82-92) F Bodies, (93-Up) F Bodies might require the steering rack to be lowered or the engine mounts shimmed. Makes a great late F-Body Drag Pan. Can be used with cross-over exhaust. Pans can be notched for steering clearance on a special order basis.
Canton
Was there any issue in dealing w/ the fitment of the pan?
Old Oct 21, 2004 | 11:36 AM
  #71
Z95m6's Avatar
Re: LT1 Weaknesses
I wouldn't waste my money on a bigger oil pan the stocker works fine. That is money you could be putting towards a better cam or headers. Just my opinion
Old Oct 21, 2004 | 11:44 AM
  #72
Seal's Avatar
Re: LT1 Weaknesses
2 bolt?
Old Oct 21, 2004 | 11:47 PM
  #73
Jerm's Avatar
Re: LT1 Weaknesses
A quote from the first post in the thread...
I did a search and have found a world of conflicting opinions.
The car sees a lot of road racing, so my goal in the rebuild is to make sure I cover all the LT1 weaknesses.
It's not bigger and the reason why it interests me is to prevent oil starvation. Last time I checked, a dry sump system can get pretty expensive, so I definitely do not want to go that route
BTW, the best price I've found on Mac Midlenghts w/ dual cat is 675, can anybody beat that?
Old Oct 21, 2004 | 11:50 PM
  #74
Jerm's Avatar
Re: LT1 Weaknesses
Originally Posted by Seal
2 bolt?
Old Oct 22, 2004 | 12:07 AM
  #75
Z95m6's Avatar
Re: LT1 Weaknesses
sorry about that. I figured you were wanting a deep sump pan. Some times i forget guys like to corner. 99% of the guys on here like to go fast in straight lines.
