LT1 Valve Covers
Old May 2, 2012 | 03:26 PM
Camarokid95's Avatar
LT1 Valve Covers
Will these valve covers work for a stock LT1?
Proform 141-107 GM Performance SB Chevy Short Chrome Center Bolt Valve Covers | eBay
Old May 2, 2012 | 04:16 PM
Dave89IROC's Avatar
Alternator might hit the front of the passenger one, but not by much
Old May 2, 2012 | 05:19 PM
Re: LT1 Valve Covers
Any suggestions for making it fit if its tight?
Old May 2, 2012 | 06:14 PM
96z28_lt1's Avatar
somewhere on this interweb is a guide on how to do it, you basically have to trim a part of the altenator housing with a dremel or such
Old May 3, 2012 | 02:37 AM
lt1-xjs's Avatar
It's a std short cover, it should just bolt on.
Old May 3, 2012 | 05:08 AM
But it appears it's missing the notch in the front of the passenger side that the stock LT1 cover requires to clear the bottom/back of the alternator.
Old May 3, 2012 | 12:12 PM
lt1-xjs's Avatar
I don't remember the stock covers having a notch, I run the "tall" 141-131 Proform covers and they're not notched. Massaged the alt a bit. Others have used the same covers also.
Old May 3, 2012 | 05:01 PM
There's a notch on my 94, and a "search" will turn up numerous posts on other LT1 sites discussing the issue with the "notch". Take a look at what Canton did to allow their aluminum valve covers to fit with the stock alternator.
Old May 3, 2012 | 06:27 PM
97WS6SCharged's Avatar
Yep, they have a notch for the alternator to clear. The Proform covers will fit but you may need to disassemble and clearance the back of the alternator just a little bit.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
Jul 4, 2005 05:00 PM
