some stupid noise.
If it sounds exactly the same with no belt, I'd say it's most likely the water pump....don't drive it, if the pump lets loose, not only will you be stuck somewhere, but it may soak your Opti, more $$ then. If you don't have a mechanics stethoscope, get a 2 foot piece of hose, put one end in your ear, the other end behind the water pump...move the hose around; it will become obvious where the problem lies. Report back, and good luck!
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 09:20 AM
cmsmith
Aug 9, 2015 07:30 PM
