Lt1 timing chain loose?
Old May 3, 2010 | 02:58 PM
kevinz2895's Avatar
bought a new timing chain for my 95 z28 and put it on. the chain seems a little loose, is that a concern. it is the right chain for the car i checked the part#. Does GM make the chain loose so it can go on the gears?
Old May 3, 2010 | 03:08 PM
Has the crank ever been changed, and the block align bored?
Old May 3, 2010 | 03:22 PM
kevinz2895's Avatar
I just pulled the engine and took it to a local machine shop. The block did not need to be bored but the crank got swapped out for another lt1 crank that didn't have to be turned as much.
Old May 3, 2010 | 03:28 PM
wrd1972's Avatar
A new chain will be tight and its normal for it to loosen up a little, within reason.
Old May 3, 2010 | 03:41 PM
Seems LT1 chains are a little on the loose side. If you did not also change the gears (which you should do when replacing a chain), then it might not be as tight as it could be.
Old May 3, 2010 | 03:51 PM
kevinz2895's Avatar
I did put all new gears on but the chain just seems a little loose. The chain isn't snug its a little on the loose side but its nothing extreme. I'm just trying to find out if these chains have a tendency to be more loose than snug.
Old May 3, 2010 | 04:42 PM
LearJet's Avatar
LT1 timing sets are a little looser than what you would normally see if you are used to seeing older SBC's.
Old May 3, 2010 | 06:00 PM
RUDEDOG's Avatar
I used an LT4 Extreme set and it was on the loose side. Never had a problem.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
