lt1 shortblock same as 70s 350 ?
Old May 3, 2011 | 09:41 PM
twistedbowtie's Avatar
Question lt1 shortblock same as 70s 350 ?
im wondering if anyone knows if a lt1 top end will bolt on a old 350 shortblock? is the head bolt pattern the same?
thanks
Old May 3, 2011 | 09:43 PM
95zsean's Avatar
Re: lt1 shortblock same as 70s 350 ?
Not without serious machine work to the heads.....
Old May 3, 2011 | 09:44 PM
RamAir95TA's Avatar
Absolutely no rhyme or reason to put LT1 heads on a Gen I SBC. It's never been done, for several reasons.
Short answer, no.
Old May 3, 2011 | 09:47 PM
thanks ive never compared the two block and gota rebuild my lt1 soon so thought id try and get a answer on that.
Old May 3, 2011 | 11:32 PM
Actually, the LT1 heads and intake are popular for the 3rd Gen guys. Its a matter of plugging up a couple coolant passages and drilling a couple new ones. Cheaper and lighter than a set of Vortec heads.
In addition to the head coolant passages, the entire front of the Gen 1 SBC and the LT1 blocks are totally different, due to the water pump provisions and the Optispark distributor drive.
Read this:
http://www.enginebuildermag.com/Arti...t1_engine.aspx
Old May 4, 2011 | 12:12 AM
97WS6SCharged's Avatar
Also requires a remote thermostat.
Old May 4, 2011 | 08:31 AM
6SpdLT1Z's Avatar
Short answer, no.
x2.
Old May 4, 2011 | 05:05 PM
thanks frank that is what i was wondering.
it was just a thought and wanted a good answer. not just there is no point or why would you do that? thanks for all responses though helped my reasoning allot.
Old May 5, 2011 | 12:13 AM
It's really only economical to swap if you can do the machine work yourself. Once you pay for someone else to do the work to the heads you'll be into the conversion for what a good aftermarket heads will cost.
Chris Anderson
Jan 27, 2015 08:30 AM
Jrlt1
Jan 3, 2015 07:38 PM
4586
Dec 6, 2014 05:20 PM
Queens94z28
Nov 20, 2014 06:03 PM
