LT1 Seafoam
Old Feb 27, 2006 | 10:38 PM
CamaroGuy22's Avatar
LT1 Seafoam
Yes I realize that there have been a ton of posts about this. But lets make a new one. List your experiences with this product. I am thinking of using it before I change out the headers, 02 sensors, cam, water pump, rockers, valve springs, lifters. How long have you guys been using this stuff? How long till your engine blew up? What caused the failures? I have done alot of reading on this, I would like to have my motor all cleaned out. Is there anything I should look out for like oil pump failures? Talk about it below.
Old Feb 27, 2006 | 11:35 PM
transamdude95's Avatar
Re: LT1 Seafoam
I haven't blown my motor or had any internal problems, but I have used the Seafoam once. It seemed to do a good job of cleaning, but I'm sure continued use will see the most gain out of it instead of just a one-time deal. There is a lot of smoke that comes out when using it, so just make sure you work it all through before driving because it may seem to be done smoking... but once you start to drive it starts again. I can't remember if I put any in the oil.... or if you are even supposed to, it's been a while. I just poured it into a vac line on the TB and made sure to do it slowly hehe.
Old Feb 28, 2006 | 12:43 AM
amean94ta's Avatar
Re: LT1 Seafoam
i used 6 cans in a row when i worked at monro and was bored one day if was free for me anyway lol i get 300+ miles a tank on 87 now but dont expect same results
Old Feb 28, 2006 | 03:31 AM
bad95formula's Avatar
Re: LT1 Seafoam
Youre runing 87 octane in a 398 with 13.8:1 compression? Youre a brave soul!!
Old Feb 28, 2006 | 07:30 AM
Re: LT1 Seafoam
CamaroGuy22
When you end up with multiple posts from clicking the "Submit Reply" button more than once, PLEASE go back to your duplicates and delete them. Click the "EDIT" button and you will see an option to delete the post.
Old Feb 28, 2006 | 12:03 PM
Re: LT1 Seafoam
Originally Posted by Injuneer
CamaroGuy22
I never noticed I had duplicate posts? I know how to edit them just fine thanks for explaining though.
Old Feb 28, 2006 | 12:10 PM
Honda Hunter's Avatar
Re: LT1 Seafoam
lol. Not sure if it helps but Ive heard nothing but posotive. I hear they can be hell on o2 sensors though.
Old Feb 28, 2006 | 05:48 PM
Re: LT1 Seafoam
I have heard the same. I figured I was changing the cat, 02's out which are the parts I hear everybody messes up. I have also read some horror stories. Want to feel more comfortable with the product before I go sticking it into my engine.
Old Feb 28, 2006 | 06:25 PM
1 Nasty Bird's Avatar
Re: LT1 Seafoam
I use it on everything i own. Awesome stuff, usually get a much better idle out of teh motor after using it.
Old Mar 17, 2006 | 08:14 AM
superkia8's Avatar
Re: LT1 Seafoam
When I used it on my 96 LT1 with over 100k on her, I was replacing my 02's and about to do a complete tune up so I dont know if it helped it or not? Now it did smoke like crazy though! I see lots of posts saying it will hurt 02's but usually they are all from people that have not tried it, I dont see too many people saying they had personally had a problem out of it? I will be putting it in my probe here soon so I will let you know what happens with it.
Old Mar 17, 2006 | 08:43 AM
wrd1972's Avatar
Re: LT1 Seafoam
I put in the 4.0 in my Jeep wrangler. Smoked like crazy like its supposed to.
The engine runs smoother but I dont feel any gains. I will start gauging MPG.
I have added a full can to the gas tank.
The jury is still out if it will go in the z28.
Old Mar 17, 2006 | 09:27 AM
chrisn's Avatar
Re: LT1 Seafoam
I do it and i generally run it through right before i change my plugs because i can imagine that it could foul them up pretty bad.
Old Mar 17, 2006 | 11:52 AM
kingman109's Avatar
Re: LT1 Seafoam
http://media.putfile.com/seafoam_kingman109
was very nervous @ 107k but afterwards ive never had the car idle better. car had been sitting in a junkyard for 2 years so i figured it could use it - think i poured can in gas- and sucked 3/4 of can through my brakebooster line- just held it and poured in slowly untill about halfway then poured rest till she stalled...let her sit for 10 min and on 2nd try she started up.....
just make sure you change your oil pretty soon afterwards.
i lucked out and O2's and sparkplugs held up fine for another year untill i decided to build the motor.
good luck
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
