LT1 rotating assembly balance?
Old Mar 13, 2014 | 01:48 PM
4th Gen 4 Life's Avatar
Is the lt1 Internal balanced from factory? Im guessing it is but not sure? My 94 Z28 has a shake around 3k on the rpms. Sitting still or crusing at 60mph. Its not a horrible shake but a annoying one. I know the transmission has been into and probably done wrong. I plan to take it out and replace torque converter, seals and filter. The flywheel and torque converter seem to be solid but not 100% sure. Could the flywheel be loose??
When i installed new opti the front crank pulley bolts were loose but i know its right now. What could be causing this shake. No codes also.
Also will the shifting linkage from a 95 v6 auto interchange with a 94 z28 auto?
Sent from my DROID X2 using Tapatalk 2
Old Mar 13, 2014 | 02:03 PM
Re: LT1 rotating assembly balance?
The LT1 is neutrally balanced on the front and externally balanced on the rear.
The shift cable is the same.
Old Mar 13, 2014 | 04:37 PM
Thanks shoebox my best bet would be to check out my flywheel i believe. Also the linkage clips are broke so ill be sure to swap that over.
1996LT1Z28
Dec 1, 2014 01:01 AM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
rje
Sep 9, 2002 12:35 PM
