LT1 question...???
Old Apr 27, 2006 | 12:17 AM
robb4964's Avatar
LT1 question...???
Ok, I have a friend with a 95 LT1 that runs perfect,uses no oil and has plenty of power. The car hass good oil pressure but I have a question about startup. When he first starts the car its makes a noise from the lower half of the engine for a few seconds and stops completely after running for a few minutes. Kind of like a brief lack in oil pressure.
Just wondering what you guys think is causing this? He is afraid to cam the car due to the noise But I dont think its a real issue. It is not a lifter as it is coming from the bottom of then engine.
Any thoughts other then a lifter?
Old Apr 27, 2006 | 07:42 AM
Re: LT1 question...???
The LT1 will often produce a bit of piston slap on cold start. Is that what it sounds like?
Old Apr 27, 2006 | 01:03 PM
robb4964's Avatar
No..sounds more like a short knock. Like it sounds right after an oil change when the oil hasnt fully circulated.
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
MissedShift
9
Jul 17, 2002 10:31 PM
Brent94Z
Mar 21, 2002 04:44 PM
