LT1 problems
Old Oct 6, 2003 | 09:16 AM
ProtoX's Avatar
LT1 problems
I have friend who just rebuilt his 94 Z28. We have it all back in and together but it won't start. It is getting fuel but no spark. He has new opti. PLEASE HELP
Old Oct 6, 2003 | 11:34 AM
ProtoX's Avatar
ttt
Old Oct 6, 2003 | 11:51 AM
IXLR894Z28's Avatar
Double check all your connections, especially the coil.
Old Oct 6, 2003 | 03:46 PM
ProtoX's Avatar
It is a pretty new coil. We have check all the connections
Old Oct 6, 2003 | 03:49 PM
jonaddis84's Avatar
How do you know it has fuel but no spark? Make sure the coil is plugged in off the opti well. Make sure the wiring harness is plugged in the opti well. other than that, bad opti (even though its new), bad coil(same thing).
Old Oct 6, 2003 | 03:51 PM
ProtoX's Avatar
You can smell the fuel. Is there any way to test opti, or coil?
Old Oct 6, 2003 | 03:56 PM
jonaddis84's Avatar
Opti no. Coil i think so, it should have X? ohms of resistance. if you have a LT1 too just take yours off and put it on his, coils are the cause of the problem only like 5% of the time from what i hear, if that. I would say triple and quadruple check your connections. When i was starting mine i checked everything like 4 times but forgot to hook up the vacuum hose to the FPR since i broke it when removing it.
Old Oct 6, 2003 | 04:14 PM
BOWTYDE's Avatar
How did you check for a spark? Did you pull a plug out and hold it to the block and watch for a spark while you buddy turns the key?
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
