LT1 problem
Old May 18, 2013 | 02:57 PM
turnerracing354's Avatar
LT1 problem
I just had my LT1 rebuilt last year. Everything is all new. It got a mild cam, heads were gasket matched and reconditioned. Ive had a problem problem with an high idle and cant seem to figure it out. I had the pcm tuned, repaced the IAC, and have checked all over for vacuum leak and cant seem to find any. Now to top it off the exhaust is popping and has a little misfire.
Any help would be appreciated
Old May 18, 2013 | 03:17 PM
Re: LT1 problem
Have you done a scan data log to see how the IAC "counts" are responding to the high idle? Have you checked the throttle stop screw to make sure it's not keeping the blades open too far? Checked the throttle cable to make sure it's not hanging up?
Excellent free (for 20 uses) scanning software..... you scan it, we'll review your data log:
TTS Power Systems
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
