LT1 over 7000
Old Mar 5, 2008 | 01:25 PM
  #16
Originally Posted by My Red 93Z-28
Like Injuneer has said if you want to go over 7000 rpms, you need an aftermarket PCM and possibly some adjustments to the opti unless you go with a LTCC or other coil-pack igntion......
That's not what I said.....
Old Mar 5, 2008 | 01:30 PM
  #17
Z28SORR's Avatar
You've become so famous, or is that imfamous, that now your being miss quoted.
Old Mar 6, 2008 | 10:20 AM
  #18
526 SS 96's Avatar
You can turn the engine as high as the rotating assembly and valve train are designed for. Problem with the stock PCM is that the tables only go up to 7,000rpm. But you can turn more than 7,000rpm on the stock PCM... it just runs on the 7,000rpm values. Means the 7,000rpm table values/programming have to take into consideration that the engine will actually be turning more than that. It may also put a bit of a strain on the distributor rotor. For vey high RPM, something like the LTCC ignition, which uses only the optical sensor in the distributor might provide better results.
Or, go to an aftermarket ECU and the sky is the limit.
Good post.
Here is a short video of my car turning 7,500 RPM on the dyno. I shift at about 7,500, but I have turned it 8,000 on a missed shift.
Old Mar 6, 2008 | 11:31 AM
  #19
rskrause's Avatar
Moderator
Stock PCM at 7,300rpm:
Rich
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Timberwolf
Sep 2, 2002 10:42 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
