LT1 Oil Level Sensor connector help?
Old Apr 30, 2009 | 09:14 PM
crazypurgatory's Avatar
On my 97 Z28 I want to put a fire sock or what ever you call it on the wires because that aluminum foil tape is gone and I don't want the wires to melt.
Do the wires come out of the connector?
I can't seam to figure how they come out and I don't want to break it.
I don't want to cut them.
Thanks,
Old Apr 30, 2009 | 09:23 PM
You have to reach down into the connector and release it. A small screwdriver can usually get in to do it.
Old Apr 30, 2009 | 09:29 PM
Is that from the plug side or the back side where the wires come in to the connector?
looks like this one with out the blue clip.
http://cgi.ebay.com/ebaymotors/LT1-L...ayphotohosting
Thanks,
Old Apr 30, 2009 | 11:19 PM
It's a regular, old connector, you just have to reach in there to unclick it from the opposite direction as you normally would.
Old May 1, 2009 | 07:51 AM
meissen's Avatar
I think his question was how do the wires pull out of the metripack plug, not how they unplug from the sensor. Unfortunately, I don't know, but trying to help clarify.
Old May 1, 2009 | 12:59 PM
Yes thats what I'm trying to do.
I need to take the wires out because the fire sleeve is to small to fit over the connector.
Old May 1, 2009 | 02:08 PM
You'll have to use a tool to remove the pins from the connector. I think eficonnection.com has some.
Sorry about being on the wrong track.
Old May 1, 2009 | 03:27 PM
no problem.
They have some tools their but I have know idea what one would work on that connector.
And there not cheap either 30 bucks.
I can buy three of the pigtails for that.
I'm going to try to find the pigtail on one of my junk harness's and see how it comes apart.
I have found that most of the connectors will come apart with out the tools just might take a little more time.
And of coarse if you have know idea how they come apart they take longer.
HectorM52
Jul 30, 2017 11:46 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
