Lt1 no start
Old Oct 28, 2011 | 03:28 PM
chris79792000's Avatar
Lt1 no start
Allright guys, this is continuation from the granatelli thread. I checked fuel pressure today. It jumped straight to 45 when the key was hit and then settled around 43. I also took the icm in and had it tested. They tested it ten times in a row and no issues. The one thing that concerns me is, I pulled the plug wire off the spark plug and placed in another spark plug and had my dad crank it over. It sparks, but looks almost yellow/orange, not the good blue color it should be. I tried a coup[le different plugs same result. I'm pretty sure it's ignition related at this point since I have good fuel pressure. I have a msd blaster coil on now and even tried the original and it still won't start. So now the question is will a faulty opti cause this weak spark? Like I sai in the previous thread I just replaced the cap and rotor with a msd, but didn't change the optical portion. I did loctite the rotor also. I'm thinkin the opti crapped out what do you guys think? Anything else that would cause the weak spark. Also the only code I retrieved was po 300 multiple missfire. Need help this thing is drivin me nuts.
Old Oct 28, 2011 | 04:29 PM
vangill's Avatar
Re: Lt1 no start
are all your grounds good?
Old Oct 28, 2011 | 04:45 PM
Unhappy Re: Lt1 no start
As far as I know, the only one I would have taken off was the one by the coil and I'm pretty sure It's tight. Like I said in the previous thread whatever happened came on quick. The first time I started it after the Cai upgrade it ran fine. Then the next day I went to drive it it ran like crap and kept getting worse to now where it won't start. Still need to check that the objectors are pulsing, however I beloved it is spark relates at this point. And with a yellowish spark I know it isn't throwing the heat. Like I said I even tried the old coil and that didn't work so I don't think its the coil either.
Old Oct 28, 2011 | 05:10 PM
Re: Lt1 no start
A problem with the optical cam position sensor won't cause a weak spark. And, a problem with the optical sensor will set a code.
Old Oct 28, 2011 | 06:00 PM
vangill's Avatar
Re: Lt1 no start
what plugs and whats the gap
Old Oct 28, 2011 | 07:03 PM
Re: Lt1 no start
Ngk 55's I belive. And I think I set them at factory gap.
Old Oct 28, 2011 | 07:05 PM
Re: Lt1 no start
If something was wrong with the cap it would cause a weak spark correct?
Old Oct 28, 2011 | 10:59 PM
Re: Lt1 no start
Could be. The Opti high voltage section is just like any other distributor. Corroded wires/terminals, cracks, dielectric breakdown of the insulation the separates the internal conductors that route the contacts to the side terminals, burned terminals or rotor, faulty bearing (but that's in the part you didn't replace).
Old Oct 29, 2011 | 09:21 AM
Re: Lt1 no start
Thanks, I'm just going to replace the whole unit with and ac part. AT least I'll have peace of mind that the whole unit is new. Hopefully that cures the issue. If not back to beatin my head against the wall. Thanks everyone, awesome site learnin alot. Also nice to have so many people that are willing to help.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
