lt1 or lt4?????
Old Dec 10, 2006 | 08:56 AM
pitbbull racing's Avatar
lt1 or lt4?????
how do u tell the diffrence between a lt1 and a lt4????????thanks
Old Dec 10, 2006 | 09:37 AM
2000GTP's Avatar
Here is a site that gives a good comparison: http://www.grandsportregistry.com/lt1vslt4.htm
Old Dec 10, 2006 | 09:40 AM
bitchin94's Avatar
the biggest diff is 4 bolt main and 2 bolt main the lt1 has a 2 bolt and the lt4 has a 4 bolt there are other things like the intake, cam, and valve train but I think the 4 and 2 bolt main is the biggest
please correct me if im wrong
Old Dec 10, 2006 | 10:13 AM
Dave89IROC's Avatar
not quite, there are 4 bolt LT1s
Old Dec 10, 2006 | 10:34 AM
All Corvette LT1's are 4-bolt mains, and all F-Body factory "replacement" (warranty) LT1's had 4-bolt mains. There is absolutely no difference between a C4 LT1 and a C4 LT4 block.
Old Dec 10, 2006 | 11:43 AM
DrewHMS97SS's Avatar
When doing my rebuild, I searched for a C4 block for the 4 bolt main, everyone I found had a 2 bolt. Were there years that the c4 had a 2 bolt?
Anyhow, the cam, rockers and heads are the biggest difference. If you are just trying to tell which you have, the color of the intake is the easiest thing to look at, as the LT4 came with a red powder coated intake.
Old Dec 10, 2006 | 01:07 PM
huskersZ's Avatar
92-96 lt1 vettes were 4 bolt mains.....any block from a vette from those years should be 4 bolt mains.
Old Dec 10, 2006 | 04:42 PM
formulalt4383's Avatar
I got my block from a 93 Vette and it has 4 bolt mains in center section (the ends are still only two bolts) but all factory Vette LT1's should be 4 bolts or it came out something else.
Old Dec 10, 2006 | 06:55 PM
red94chicken's Avatar
on the heads under the valve covers the lt4 heads have lt4 cast on the top of one of the intake runners. all vette blocks are 4 bolt mains.. if you have a 2 bolt main in a vette someone must have swapped the block. also for lt4's the vin number would be a "5" not a "P".
Old Dec 10, 2006 | 07:24 PM
thanks everyone
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
