LT1 to LS1 injectors
Will the LS1 injectors swap for the LT1 injectors ? I keep seeing the 26lb. LS1 and 28lb. LS1/ZO6 injectors on Ebay, with some advertised as " a great upgrade for an LT1." However, the coil on these injectors looks a lot smaller, so I'm wondering if the impedance is different. In other words, if you install a set in an LT1, will the drivers for the injectors in the ECU get fried
If you do a search in this forum or just look back in the past 10 or so pages you will find some recent posts with a lot of good info about doing this swap.
I plan on replacing my stockers with some LS1/6 injectors here soon, so I'll post on how I make out.
99-00 LS1 Injectors are 26.4lb/hr
ZO6 is 28.4lb/hr
All of these are at 4 bar pressure (58psi). The LT1 uses 3 bar (43.5psi). If you take a stock LT1 24lb injector and run it at LS1 pressure, you'll have 28lb/hr injectors. If you install an LS1 injector in you LT1 at the stock pressure, you'll have 24lb.
Doing this swap will work, but get you exactly 0 increase in flow, and thats if you go w/ the 28. A waste of $$.
Originally posted by BlackCamaros
So if I purchase an Accel 24# injector, what am I getting ? If I put that injector on my LT1, will it flow less, more, or 24# ? Isn't there a standard that injectors are rated at ?
My 39SVO injectors, which would flow 39lb/hr at 40psi, are now flowing 47lb/hr in my LS1.
Sergio
Jan 27, 2016 04:27 PM
Jul 4, 2005 05:00 PM
