LT1 Keyed hub
Old Aug 9, 2008 | 12:15 PM
lt1ks's Avatar
LT1 Keyed hub
Does anyone know of a keyed hub I can buy...thunder racing has one (on back order) made by a co. in china.....does any one else sell one
Old Aug 9, 2008 | 12:29 PM
CNC Cylinder Heads used to key stock LT1 hubs, but I'm not sure if they are still in business - the website hasn't been finished for years:
http://cncheads.com/
Old Aug 9, 2008 | 12:56 PM
lt1ks's Avatar
Thanks....tried them, no way to contact...let me know if you have a # for them....thanks
Old Aug 9, 2008 | 01:30 PM
cnorton's Avatar
ATI sells both steel and aluminum keyed hubs. I suspect that they will only work with the ATI dampner but the quality is excellent.
Old Aug 9, 2008 | 02:16 PM
lt1ks's Avatar
thanks
Old Aug 9, 2008 | 04:26 PM
mdenz3's Avatar
Any decent tool and die shop shuold be able to put a key in a stock hub for you.
Old Aug 9, 2008 | 09:06 PM
87Aerocoupe's Avatar
Thunder Racing used to sell modded stock ones, try thunderracing.com.
Old Aug 9, 2008 | 09:28 PM
97WS6's Avatar
They still do. Here's the part numbers:
41-872049 Pioneer Keyed Crankshaft Hub, 1996-1997 LT1 F-body & 1996 LT1 Corvette Keyed Crankshaft Hubs $85.00
41-872015 Pioneer Keyed Crankshaft Hub, 1992-1995 LT1 F-body & Corvette Keyed Crankshaft Hubs $85.00
41-872016 Pioneer Keyed Crankshaft Hub, 1993-1995 LT1 Impala and Caprice Keyed Crankshaft Hubs $85.00
The site doesn't mention whether or or not they're in stock so give them a call.
97WS6
Old Aug 9, 2008 | 10:13 PM
DAVE00's Avatar
Bought one from Jegs for my 95 not to long ago and it's excellent quality. Here are the links:
93-95
http://www.jegs.com/i/JEGS/555/51607/10002/-1
96-97
http://www.jegs.com/i/JEGS/555/51609/10002/-1
FYI - Your stock HBalancer/pulley will bolt right up (just have to pull the guide dowl pin)
Let me know if you need any advise or have any questions.
Old Aug 10, 2008 | 12:27 PM
lt1ks's Avatar
Hey guys thanks alot...The jegs piece looks good...thunder is out of stock
Old Aug 11, 2008 | 01:24 AM
Dave1980's Avatar
FWIW the jegs piece looks exactly like what i got from thunder.
Old Aug 11, 2008 | 10:02 AM
MichiganSkip's Avatar
Where would a guy index the key if he had the ability to key one himself?
Old Aug 11, 2008 | 10:18 AM
DAVE00's Avatar
Go to any autoparts store or even Ace Hardware and you can buy a bag of various sizes of keys. The stock crank has a key slot (just not key'd from the factory), but I am not exactly sure what size the stock key is so try different sizes.
FYI - if you meant key the hub, then pretty much any auto machine shop can do it for you ranging from 20-50 bucks depending up on their knowledge and prices.
Old Aug 11, 2008 | 10:48 AM
Where would a guy position the key slot on the hub when keying a hub himself? I can slot the hub myself. Just need to know where to put it.
Old Aug 11, 2008 | 10:51 AM
DAVE00's Avatar
Mark where the empty slot is on the crank snout relative to the hub when you remove it and notch the hub there.
