LT1 Keyed hub
Old Aug 11, 2008 | 05:25 PM
  #16
Originally Posted by DAVE00
Mark where the empty slot is on the crank snout relative to the hub when you remove it and notch the hub there.
There is no certainty that the hub was correctly located on the crank snout, since there is no key.
Old Aug 11, 2008 | 05:34 PM
  #17
mdacton's Avatar
imo what would it matter where you put the keyway? The thing is nuetral balanced and there is not tdc mark etc. on it so whats it matter?
Honestly the stock pc. is made for a stock car......save a few bucks and get a good damper from ATI. I'm sure everyone here has seen stock style ones push the rubber out.
Old Aug 11, 2008 | 05:41 PM
  #18
DAVE00's Avatar
Agreed!!!
Old Aug 11, 2008 | 06:50 PM
  #19
Green96Z's Avatar
Originally Posted by s_willis
Where would a guy position the key slot on the hub when keying a hub himself? I can slot the hub myself. Just need to know where to put it.
With the engine at TDC, position the hub so the little arrow on it points at 12 o clock. Then slot the hub where the keyway on the crank is.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
