LT1 Intake Powder Coated
Old Jul 31, 2008 | 03:17 PM
  #16
GMH94Z28's Avatar
That's what i was going to try. Thanks
Old Jul 31, 2008 | 03:25 PM
  #17
cause4panic's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=95793
Old Aug 1, 2008 | 02:15 AM
  #18
SS RRR's Avatar
Don't worry about it. The LT4 intake manifold is the same way.
Old Aug 7, 2008 | 10:39 AM
  #19
GMH94Z28's Avatar
I bought some permatex gasket removal on it and it is coming off pretty easy.
Old Aug 9, 2008 | 06:08 AM
  #20
1lowZ-28's Avatar
powder coat
if it was me i would just remove what you dont want. i have had similar problems with powder coating. take some painters tape and make a border were you want to remove the powder. then take a razor cut along the tape to make a nice line. get a die grinder with a 3M scotch bright pad and remove what you dont want. the rest of the powder coating SHOULD not flake or be effected. but it depends on how many mil thick it is and how well the area was prepared before they coated it. if you are still gun shy after you remove the excess get some brake caliper paint from your local auto parts store and go around the seam of what you just took off.
good luck
Old Aug 12, 2008 | 10:11 PM
  #21
GMH94Z28's Avatar
I took it back today for them to redo it. I told them today not to spray the bottom at all. It was too much work trying to remove it all.
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
