LT1 intake identification
Old Feb 19, 2020 | 10:01 PM
wbacall's Avatar
Hi, I am looking for a back up intake manifold for my 1994 Z28 Camaro. I have searched and still can’t find how to ID the manifold. Will any 94-97 work the same? I see some have a pcv hose to the front and some have a u shaped hose. I understand 93 is different and won’t work. I have seen conflicting information on casting numbers and port shape. I am asking how to ID and also if someone has one for sale. Thank you 😎
Old Feb 19, 2020 | 10:15 PM
Re: LT1 intake identification
The 94-97 manifolds are all the same. The external attachment (separate parts) are different. You would simply reuse the U-shaped PCV valve vacuum hose from your current 94, and put the correct size pipe plug (again, from your 94), in the tapped vacuum port under the throttle body. The differences in plumbing are simply different ways of using manifold vacuum to pull the crankcase gasses into the plenum.
Only the LT4 intakes have different port shapes.
Old Feb 19, 2020 | 10:45 PM
wbacall's Avatar
Is the L99 also the same? So if it looks like mine it’s good? Thank you so much!
Old Feb 20, 2020 | 01:43 AM
I have no idea if the L99 intake is the same. Was not aware you are looking at other than F-Body intakes.
173rd
Jan 9, 2014 11:49 PM
96z402
Jan 3, 2010 05:39 PM
Mtxz453
Aug 21, 2008 08:13 PM
Jun 30, 2006 08:00 PM
96_pimped_out
Jun 14, 2005 10:38 PM
