What goes in this hole? (Front of Intake Manifold)
Old Jun 13, 2005 | 02:57 PM
96_pimped_out's Avatar
Underneath the throttle body on the front of the intake manifold (in the center) there's a connector of some sort. It's just behind the top of the water pump, see in this pic:
http://shbox.com/ci/ci267.jpg
However, I can't find it in my Haynes or factory service manuals. Can you guys tell me what that is that connects there?
Old Jun 13, 2005 | 03:01 PM
Compstall's Avatar
Re: What goes in this hole? (Front of Intake Manifold)
Hmmmm, mine has a plug in it.
speedcrazy's Avatar
pcv tube goes from the pcv valve on driver side intake to the front connection on intake. i think?
Old Jun 13, 2005 | 03:14 PM
That sounds reasonable... I hadn't looked where that PCV hose went to yet. I'll go make sure that makes sense and based on Compstall's post, some just delete the PCV valve and hose?
Is there any reason to remove it? I always thought they were actually one of the few good emissions control devices that didn't hurt anything...
Old Jun 13, 2005 | 03:41 PM
Yes, it is for the PCV vacuum on 1995 and later. Best to leave the PCV working, IMO.
Old Jun 13, 2005 | 04:51 PM
Compstall's Avatar
Mine came from the factory that way.
Old Jun 13, 2005 | 04:52 PM
Yup, you guys were dead-on and I hooked PCV back up. I took this thing apart 8 months ago any my memory is bad.
Thanks again for shoebox's info page and his replies!
Old Jun 13, 2005 | 04:55 PM
You and shoebox will have to duke that one out... I have no idea!
Old Jun 13, 2005 | 04:58 PM
Read what Shoebocx typed. The "95 and later" engines use the port under the throttle body for PCV vacuum. On the 93 and 94 cars (yours), the hole is plugged up, and the vacuum is supplied via the u-bend hose that reconnects into the side of the manifold.
Old Jun 13, 2005 | 08:54 PM
BigJustinZ28's Avatar
I thought the PCV was that hose that ran from my passenger valve cover into the side of my throttle body ??? Im confused
Old Jun 13, 2005 | 10:48 PM
That is the fresh air feed for the CCV/PCV system. There is no PCV in the RH valve cover.
Old Jun 14, 2005 | 10:21 PM
hmmmmm. I know what PCV stands for but I never thought about what it means. If thats just a fresh air feed than is thier any benefit in putting a valve cover breather in its place ? Instead of having it vent into the t/b like it does ?
Old Jun 14, 2005 | 10:38 PM
tc3's Avatar
tc3
no, did a little search earlier and a valve cover breather will be one big vaccum leak. but you can get a filter that is enclosed to keep the oil from getting into the line, but thats it...
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
