lt1 help
Old Dec 15, 2010 | 06:36 PM
ndeaton's Avatar
Unhappy lt1 help
Hello, im having some problems with my 1994 camaro z28. I live in Cincinnati Ohio and right now its fairly cold out (around 10-35 degrees) and ever since it has been like this my car takes forever to start meaning I have to crank on it forever for it to actually fire and keep the engine going. Its not the battery or the starter because its a really fast crank. Also today after I got it warmed up I drove it to auto zone and I was in there for 5 minutes and when I came out it still didnt wanna start but it puzzles me because it was just warmed up 5 minutes ago. Im just wondering is its just because its so cold out that maybe its just being stubborn?
Old Dec 15, 2010 | 06:56 PM
Kevin Blown 95 TA's Avatar
Re: lt1 help
Maybe it's a problem with the fuel pump or a leaky injector(s).
Old Dec 15, 2010 | 08:04 PM
ndeaton's Avatar
Re: lt1 help
I dont smell any fuel from fuel rail or anything and I just replaced the injector o rings back in May when I fixed my blown head gasket and I replaced my fuel pump back in July. I thought maybe my injectors were dirty so I bought injector cleaner and it still hasn't shown any improvements.
Old Dec 15, 2010 | 08:13 PM
RamAir95TA's Avatar
Re: lt1 help
Have you done a fuel pressure test?
Old Dec 15, 2010 | 08:16 PM
19z28camaro02's Avatar
Re: lt1 help
Coolant temp sensor? When they go bad they have a default of -40 degrees. If you can smell fuel, check it out. But it either sounds like fuel or spark.
Old Dec 15, 2010 | 08:29 PM
ndeaton's Avatar
Re: lt1 help
I havent tried a fuel pressure test but I will. I will also try and see if its the coolant temp. Thanks
Old Dec 15, 2010 | 09:56 PM
97Z28Muscle's Avatar
Re: lt1 help
Sounds like a weak coil to me.
Old Dec 15, 2010 | 10:13 PM
czlt1z28's Avatar
Re: lt1 help
I have had the same problem. When it is raining out in the summer and extremely humid, it has trouble starting sometimes. I changed the coil to an MSD coil and was fine for a few years.....but it seems to be doing it again sometimes. I live in cleveland and it is freezing here and it will start up instantly sometimes and then not start when it is a bit warmer. Take a hair dryer to it to warm it up and if it starts up, you know its the coil.
Old Dec 15, 2010 | 10:44 PM
ndeaton's Avatar
Re: lt1 help
I have had problems with the coil before.. that is probably exactly it.
Old Dec 16, 2010 | 08:04 PM
ndeaton's Avatar
Talking Re: lt1 help
So today I tackled the task of replacing my old coil with a msd blaster coil that I bought and sure enough it fired right up! Thanks guys
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
